Trail Tech Vector with stock indicator lights?
Results 1 to 6 of 6
    Senior Member Guitarman's Avatar
    Jan 2012
    Trois-Rivieres, Canada
    167
    I'm wondering if someone successfully installed a Trail Tech Vector on his TW while keeping the stock indicator lights. I've seen one installed above the stock speedo, but I would like to replace it.
    Pictures would be welcome
    Thank you!
    Senior Member bikerjosh's Avatar
    Walnut Creek, CA
    1,066
    You mean like this?
    josh
    Not all men are capable of greatness, but all possess toughness.
    2001 TW a mod or two maybeHidden Content
    Jan 2012
    167
    That's exactly what I wanted to see! Thank you ;-)
    Do you have, by chance, a picture or a plan of the bracket you made?
    Walnut Creek, CA
    1,066
    So I removed the speedometer and used the same shape for the alum plate; just made it a 1/4" wider all around so it would sit on top of the rubber gasket. I used the same mounting holes the speedometer used to secure the plate and drilled one large hole in the plate to run all the wires through. I can try and take a picture of the underside tonight when I get home.
    BTW-I'm in the middle of the xt225 tank addition based on your write up, thanks again,
    Senior Member randucci's Avatar
    Mar 2012
    Seattle, Wa.
    134
    I just put a Vapor on mine, but I also got the bracket with the lights that goes around the unit, as I wanted to place it in the center and eliminate the stock ones. Here is a poor picture, I'll try and get a better one tonight.
    Jan 2012
    167
    Thank you guys!
    bikerjosh, don't remove anything, I'm sure I can figure how to install the thing with the info you gave me.
  1. Trail Tech Vapor speed sensor
    By Guitarman in forum Technical Help
    Last Post: 06-10-2014, 02:34 AM
  2. Trail Tech TTO temp gauge?
    By DonBenito in forum Performance and Customization
    Last Post: 05-16-2013, 09:16 PM
  3. Trail Tech Voyager GPS review?
    By NiceAndSlow in forum Performance and Customization
    Last Post: 03-23-2013, 11:23 AM
  4. Vapor Trail Tech
    By flingwing1969 in forum Performance and Customization
    Last Post: 08-21-2012, 01:33 PM
  5. New Trail Tech Vapor install for Muley
    By JS5owner in forum Performance and Customization
    Last Post: 01-01-2012, 08:01 AM
installing vector on tw200
trail tech speedo install
trail tech stock indicator
trail tech tw200
