Best brake shoes
Results 1 to 8 of 8
Like Tree36Likes
  • 2 Post By Lyterx
  • 2 Post By Purple
  • 3 Post By Xracer
  • 11 Post By Fred
  • 8 Post By TW-Brian
  • 8 Post By scotti158
  • 2 Post By Xracer
Thread: Best brake shoes
    Senior Member Lyterx's Avatar
    Jun 2014
    Etters, Pa
    474
    Best brake shoes
    Just wondering what brake shoes everyone has tried and if there was much of an improvement over the the stock shoes. Mine need replaced soon and just started to look around. EBC, Vesrah, Import, grooved shoes were some that I found. Looking to hear how these performed over the stock shoes. By the way my TW is a 1991, so I will be replacing shoes in front and rear. 24,500 miles on the stock shoes, not too bad!
    1991 TW200
    Mar 2015
    Ynys Môn
    4,631
    Given the braking potential of these bikes, I wouldn't bother with grooved pads, just blow them clean if they start to squeal
    What you do want to look for is "sintered" brake shoes - something with small metal particles embedded into them that make stopping easier
    Most modern shoes are "sintered" - but some are more sintered than others - (and still unlikely to wear out the hub because of the crap braking potential) - but every little helps
    When you do change shoes, expect less performance at first until the shoes find the hub - they'll need "bedding in" same as everything else ......
    Ken and Lyterx like this.
    - Hidden Content
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,818
    Stock..O.E.M. I've tried the rest and they are all crap!!! No power or feel but they do make a loud squealing noise so people can get out of your way.
    Fred, Ken and Peterb like this.
    19,023
    TopPredator, Ken, TW-Brian and 8 others like this.
    Pleasanton, CA
    5,781
    Fred, I didn't realize your last name was Flintstone .
    May 2013
    Groton, NY
    2,663
    My Dad built me a mini bike out of water pipe and a modified bicycle front end with a tiller engine for power. He never did get around to adding brakes but I rode it anyhow. Wore my Mom's boots out during summer vacation. Looked a lot like your shoes. She didn't find out until cold weather. Dad got blamed because of the mini bike not having brakes. Had some good times on my first vehicle that I didn't have to pedal.
    Xracer, Lyterx, Fred and 5 others like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,958
    I never noticed the brakes being an issue on my 1993. It seems to stop easily and quickly along with my 1 gear down shift. I don't like the brakes with zero pressure applied on the new bikes, that is why they need ABS.
    Lake Placid,Florida
    3,818
    A little duct tape will fix those hiking shoes no problem. Also I've found the Keen brand to be a little longer lasting.
    littletommy and Fred like this.
  1. Brake shoes
    By san_mas in forum TW200 Classifieds
    Last Post: 11-01-2013, 10:00 AM
  2. Rear brake shoes directional?
    Last Post: 09-26-2012, 10:50 PM
  3. FS: Front and Rear factory Yamaha Brake Shoes
    By xzyfsk in forum TW200 Classifieds
    Last Post: 12-15-2010, 01:15 PM
  4. Rear Brake Shoes Installation
    By thumper in forum Technical Help
    Last Post: 10-30-2010, 09:29 AM
  5. Brake pads and shoes
    Last Post: 10-17-2010, 11:29 PM
