Heidenau K60 Scout 140/80-18
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree13Likes
Thread: Heidenau K60 Scout 140/80-18
    6,944
    I am using Heidenau K60 Scout dual sport tires on my DR 650 and love them. I got to thinking that the 140/80-18 rear tire might make a good front tire on the TW. (They don't make a 130/80-18 but do make a 17. Figures....) My concern is compatibility and handling with the big rear tire on the TW and the Heidenau on the front. Anyone have any ideas what to expect? I'm concerned about going into and around curves on asphalt as well as in the dirt. Will the bike try to do something unexpected?
    Here is what a 130/80-17 looks like.
    Ephrata, WA
    1,125
    Those sure look wide! I don't know if its the tire or just the picture, but the tire looks kind of square (flat edges). I don't see why it wouldn't work.
    1990 TW200
    Looks like it would stop on a dime in the dirt. Looks rounder than typical DOT knobbies such as the K760, so probably not quite the ultimate anti-wash traction on the really slippery stuff as a K760, but probably much better road manners with less void in the tread. I expect the bigger solid blocks would feel a little more solid on pavement than the K270 and SR244. Definately looks like an excellent candidate for a replacement front tire for anything but the gnarliest offroad. Chose your compromises. I expect the $150 price will limit its popularity, but it's German, so you'll get what you pay for.
    Senior Member Phantom99's Avatar
    May 2012
    San Diego, Calif.
    194
    Metzeler makes their Sahara 3 in 140/80/18. It's slightly more street oriented than the Heidenau, but a good tire off-road. I've used them on my DR650. It also is a rear tire and also fairly expensive at around $145.
    Senior Member GapRunr's Avatar
    Jun 2011
    Friendsville, TN
    457
    I've run a few of the K60's on my DR650 and my 1200GSA. We sell them in our shop so I've had access to them to try them out. They are a great tire, but like a Kenda Big Block I wonder if they aren't too stiff for our lighter weight TW's.
    GapRunr
    Current bikes TW200 * R1200GS ADV * R80g/s * KLR250 Miami Vice Edition * Hawk GT - For sale!
    6,944
    I replaced my front tire using a 120/90-18 Heidenau K60 Scout tire instead of the 140/80 tire. The 120/90 is a much better fit. It is a much stiffer and heavier tire and 5 mm wider than the Bridgestone 130/80-18 tire which measure about 117 mm across.
    Knobbies are nice but realistically I need something that will do well on the asphalt and OK in the dirt and last a long time. I am hoping I have found the perfect compromise. Its manners on the street are perfectly acceptable though it isn't fully broken in yet I am sure it will be fine. Maybe next week I will head to Hollister and try it out in some dirt.
    The salesman said he would be surprised if I didn't get at least 15,000 miles out of this tire and he said he would not be surprised if I got 20,000. If true it will make the cost ($110 OTD) to benefit ratio an extremely favorable one. He based his prediction on the fact that when this tire is used on the rear of heavier bikes they last about 7,000 miles. Since the TW is lighter and the tire is on the front he figured it should last over twice as long. Hopefully he is right.
    ZDR1 likes this.
    Senior Member Bagger's Avatar
    Jan 2011
    Central WA
    1,050
    That looks good Tony, should do well in all but the gnarliest offroad, and looks well suited for the street.
    I just put a Michelin AC 120/90 on my front, it measured 5 3/4 " and the 140 would not have fit. I believe the wider tires are great in the real tough stuff but become a liability on the front of these light bikes in soft dry terrain, but that tire has a round profile that should help.
    Nice find!
    Bag
    "The TW may be slow, but the Earth is patient" - MK
    "If I'm wrong, and it turns out that you hate it, I'll send you all my Barry Manilow albums." LB
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Any more opinion on this tire ?.
    6,944
    Quote Originally Posted by frog13 View Post
    Nothing for the rear TW tire but lots of options if you have another bike.
    Heidenau Tires USA Distributor - heidenautires.com
    You are right, elime, selections for the rear tire is kind of slim in North America. The only DOT legal knobby available today is the stock TW34. Everything else available is pretty much a street tire. As for the front, any tread pattern from road race slick to hard core knobbies can be made to work, but most in our sizes are rear tires and some of the rear cross section profiles just don't work on the front in a variety of conditions. The secret to a good front tire is that it always has more traction than the rear, in any conditions. Washouts suck. Slideouts are fun.
    The problem with wide front tires in soft terrain is our TWs do not have enough power to loft the front wheels and keep them on top of the sand rather than p[lowing trough. Ever see an ATV with skinny tires? No? Because tire width isn't the problem.
can i fit a 140 80 17 on dr650
dr650 heidenau k60
heidenau front tire backwards
heidenau k60 dr650
heidenau k60 reverse tread
heidenau k60 scout for dr 650
heidenau k60 scout tw200
heidenau k60 tire pressure
heidenau san jose ca
heidenau scout mounting direction
k60 scout for yamaha tw200
tw200 heidenau
