Happy Trails SU rack / pannier mount
Results 1 to 4 of 4
Like Tree6Likes
  • 1 Post By Maloy
  • 3 Post By Leisure Time Larry
  • 1 Post By methamphetasaur
  • 1 Post By Purple
Thread: Happy Trails SU rack / pannier mount
    Junior Member Maloy's Avatar
    Aug 2017
    Trying to install the SU rack--the first step prior to mounting aluminum panniers--from Happy Trails. Left side fit just fine. The right side has three secure points. 1) right blinker, 2) muffler bolt, and 3) top passenger foot peg. After securing the bolts on the blinker and muffler, the foot peg is about 1/4 to 1/2 inch off. Not sure what to do. Best pic I could get is enclosed. Suggestions?
    littletommy likes this.
    Jul 2012
    Wet-ern Washington
    1,415
    I wouldn't worry about it too much. That's the deal with metal fabrication, it's very difficult to get precise repeatable results. It is close, and I'm sure it will go.
    First, I would remove the left passenger peg bolt and put some loctite on it, at least blue (med), red if you think you'll not likely remove it anytime soon. Reinstall it to finger tight then backing it out 1/2 turn so it's a little loose. Then, I would have all of the other bolts slightly loose, like the same half turn out from finger tight. Next, I'd use a ratchet strap(s) to crank things over to get the holes to line up. Also, a center punch, screwdriver, whatever to use as a drift pin type device to help line up the holes to get the bolt started can be helpful. Start that bolt, first put some loctite on it too, then torque it down. Release the straps, then go around and torque down the others. Done. Good luck.
    - Leisure Time Larry -
    Senior Member methamphetasaur's Avatar
    Jun 2015
    Colorado
    1,166
    Mine didn't fit on the right side either. The bottom hole where the rear footpegs were didn't line up. I took a drill to it and turned the hole into a slot and it worked out just fine.
    Mar 2015
    Ynys Môn
    4,631
    There was an issue of the left and right rear foot pegs having a slight off-set on some year or another - don't quote me on that - but it comes as no surprise ......
    - Hidden Content
  1. Replies: 1
    Last Post: 06-30-2017, 10:15 AM
  2. Happy Trails rack question
    By pointysticks in forum General Discussion
    Last Post: 03-12-2016, 06:08 PM
  3. Selling happy trails side and tail rack
    By acjlarsen in forum TW200 Classifieds
    Last Post: 11-29-2014, 10:29 PM
  4. Selling Happy-Trails su rack.
    Last Post: 01-28-2014, 07:32 AM
  5. Happy Trails SU Side Rack
    By immgunn in forum TW200 Classifieds
    Last Post: 06-19-2011, 04:45 PM
