Headlight mod to dual Cree bars
Results 1 to 6 of 6
Like Tree17Likes
  • 3 Post By Megawisdumb
  • 2 Post By Fred
  • 2 Post By Megawisdumb
  • 3 Post By Fred
  • 4 Post By Cornelis
Thread: Headlight mod to dual Cree bars
    Junior Member Megawisdumb's Avatar
    Jun 2013
    Alabama
    10
    I've got a 2006... any suggestions on removing stock and replacing with dual (flood/spot) led bars?
    Ken, Swingarm and jtomelliott49 like this.
    19,023
    Just do it, as long as you are not concerned about Alabama law enforcement possibly citing you for non-compliant lighting on public roads. Some of us use LED H4 replacement bulbs in order to retain stock headlight assembly and cowling for a semblance of legality. I do this even though I fully acknowledge the stock reflector will not provide as uniform a beam pattern as the depicted light bars.
    Peruse Similar Threads listed below as well as forum search engine for installation tips.
    Ken and jtomelliott49 like this.
    Jun 2013
    Alabama
    10
    I rarely see the po-po but was more worried about electrical draw. If I can wire spot on low beam and flood on high that would be ideal. Stock is 55watts correct so as long as I stay under that I should be good. Was thinking two 7" stacked. Thanks!
    Cornelis and jtomelliott49 like this.
    19,023
    The depicted light bars look to have 12 of a previous generation CREE chips each @ a nominal 3 watts/chip set thus ~36 watt draw per light. I forget where to find the exact graph of stator output vs. engine RPM but figure ~90 watts available for new millennium TWs with ~ stock 35 watt draw on low beam and 55 watt draw on high beam. Adding the shown flood light on high beam would exceed likely 90 watt total unless some of the hotel load is reduced. Those inefficient front incandescent running lights I think draw 18 watts each as well as the incandescent tail light. Disconnecting running lights, or replacing them with LED equivalents is a way to free up power to drive auxiliary lighting.
    Senior Member Cornelis's Avatar
    Mar 2015
    Centurion, South Africa
    589
    I've got good news for you, someone on the forum has already done the mod successfully . . .
    Go to Rumblefish29er https://tw200forum.com/forum/performa...tml#post191831 if you want to read the whole post
    1990 Yamaha TW200Hidden Content _____________ Come to Me, all you who are weary and burdened, and I will give you rest. - Matthew 11:28
    Jun 2013
    Alabama
    10
    NICE! On it...thanks again
  1. 90 Watt Led Headlight Mod
    By Zack in forum Performance and Customization
    Last Post: 03-25-2016, 10:25 PM
  2. round headlight / dual headlight
    By fredzaha in forum Performance and Customization
    Last Post: 05-04-2015, 02:32 AM
  3. Dual Headlight Modification
    By r_marsh in forum Performance and Customization
    Last Post: 03-13-2014, 03:57 PM
  4. Dual Headlight Setup.....Got em'?
    By Gary in Pennsylvania in forum Performance and Customization
    Last Post: 03-12-2014, 01:50 PM
  5. TW200 OR DUAL SPORT SQUARE HEADLIGHT GUARD
    By T-DUBROB in forum TW200 Classifieds
    Last Post: 08-29-2012, 12:17 AM
