Choice for a new gas tank?
Results 1 to 10 of 11
Like Tree36Likes
Thread: Choice for a new gas tank?
    Junior Member Phobos101's Avatar
    Sep 2017
    Silla, Valencia, Spain
    12
    Hi, I want to change my TW's gas tank for another with more capacity but I'm not sure about wich bigger tank fits better..
    Can somebody help me please?
    Sorry for my bad english.
    littletommy and jtomelliott49 like this.
    Lower Rio Grande, New Mexico
    1,702
    I'll make an attempt for a review off the top of my head.
    The Clarke after market plastic tank for the TW 200 only increases the volume to 2.8 gallons
    The Clarke tank for the xt350 is larger and relatively easy to adapt - somewhere around 4.0 gallons.
    The stock tank for the xt350 is larger (3.14 gallons) and easy to adapt.
    The stock tank for the xt225 is larger and has been adapted successfully. 2.3 gallons
    The Clarke tank for the xt225 is also an option. 4.1 gallons
    The xt 500 tank has been installed on the TW200 and is nearly identical to the xt350. But be careful the older bikes had a completely different tank that is longer and not suitable. Its probably about 3.14
    Rather than guess at the gallons for each of these I'll finish this message and look them up or hope that someone will provide them before I edit the post. Posts exist for facilitating installation of nearly all of these tank (here on the forum).
    Suerte. Si tiene preguntas, estamos aqui para servirle. Tomas
    A quick search shows that the xr650 L tank has been used at 5.8 gallons; and the xt500 tank was only suitable in later models that had a 3.17 gallon capacity.
    You can check years that have the same tank by doing searches on Bikeez. If too tanks from year to year have the same capacity you can probably figure that Yamaha did not change them.
    Central New Mexico
    Nov 2011
    norcal nutjob
    3,304
    i spent a almost week in valencia for las fallas 1991. camped out on the beach... wow, what fun!
    i have an oem xt225, adds 1/2 a gallon and looks really good. easy to fit, check out the link in my signature.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,473
    Just installed a stock XT350 tank and very happy with it although its probably not as simple as an aftermarket tank.
    Sep 2012
    Wichita, KS
    1,865
    Su Ingles es mucho mejor que mi Espanol. Best of luck with your search.
    Tom in Wichita
    78 Moto Guzzi SP1000
    87 Yamaha TW200
    99 Yamaha TW200
    Sep 2017
    12
    Thank's to everybody
    jtomelliott49 and littletommy like this.
    Junior Member phreadd's Avatar
    Apr 2014
    Eastern Canada, on the Ocean
    24
    Hey there joeband, do you have direct links to the installation pictures for an XT225 tank ?
    I have one coming my way very soon (I hope) and would certainly appreciate a bit of a mounting guide.
    2003 Honda 919 (CB900F Hornet) - Soon for sale !
    2006 Honda 919
    2004 TW200
    Nov 2011
    norcal nutjob
    3,304
    the link in my signature goes to the thread, but as you found, many of the pics were lost to the Eff-U-bucket fiasco.
    it's really an easy fit. cut 1/4" off each mounting post and grind the rubber pucks down enough to fit. i just rubbed them against the concrete until i could slide them in place. some people's seats seem to match up better. W-23 figured out fitting a few fender washers under the mounting bracket can help level it out.
    it's not the biggest tank, but i think it's one of the best looking swaps.
    Jun 2017
    Milwaukee, WI
    1,229
    Go plastic if you can. Especially if you plan to keep your bike a long time.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 10K miles, decent condition
    Junior Member Big Tub's Avatar
    May 2013
    1
    I figure I might revive this thread. My '87 tank has a huge dent from falling on its transport trailer. The choice is to see if it can be straightened or go with the Clarke? All the negative comments on the Clarke have me nervous. The bike can go farther than I can it one day so capacity is not an issue. My ultimate goal is just to keep this as simple and inexpensive as possible. Please advise.
    Also all the fuel lines and overflows have turned to mush. Factory replacements seem unduly expensive. Suggestions?
  1. Gas tank help
    By dlm456 in forum General Discussion
    Last Post: 11-18-2016, 06:16 PM
  2. Gas tank lines
    By elchakas in forum Technical Help
    Last Post: 07-27-2016, 05:33 PM
  3. Gas Tank
    By Sstoro in forum TW200 Classifieds
    Last Post: 05-19-2015, 08:25 AM
  4. Gas Tank 84 to 86
    By chasejamy in forum General Discussion
    Last Post: 07-09-2012, 11:21 PM
  5. gas tank
    By RisingSun in forum Performance and Customization
    Last Post: 02-03-2012, 02:47 PM
