Chain clean and lube
Results 1 to 10 of 14
    Junior Member robertgole's Avatar
    Aug 2010
    10
    What do riders use for a fast and simple chain clean and lube?
    Rob
    Senior Member Wheelie Nelson's Avatar
    Austin, TX
    204
    My link
    i use dupont teflon multi-use spray
    Senior Member Turtle Chaser's Avatar
    Aug 2010
    Fieldbrook Valley CA northcoast
    254
    +1 for Wheelie. That is the dry lube, I will never use anything else on a chain again. It does not attract dirt so the chain stays much cleaner.
    GOD BLESS & RIDE SAFE, TC____________ BC rides: Honda SL100, Honda TL125, Penton125 ISDT, KTM400 ISDT
    now riding '06 TW w/ Jimbo Window, Acerbis bushbusters, ProTaper bars w/risers, Pro Grip 737's, Osram Rally headlamp w/modulator, turn signal beeper, Kenda k270 4.00 x 18,
    triple horns w/relay, big pegs, folding shifter, tuned carb w/drilled slide, 15/50 w/D.I.D. O-ring, RedLine 20w/50, Sterns w/extra padding, extra LED brake light, xt225 brake arm, rear Cycle Racks w/hacked milk crate. Hidden Content
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,403
    The manual says to use kerosene to clean the chain. It's kind of messy.
    For cleaning, I use WD40. Spray on until the chain is thoroughly wet, then use a rag to wipe it off.
    To lubricate, I use what Wheelie uses, the Dupont Multiuse lube with Teflon. It's available a Lowe's.
    There are many motorcycle chain lubes on the market, and everyone will have their favorite.
    jb
    Senior Member mga60tw's Avatar
    Fl
    213
    can you use the dupont on the O ring chain?
    Member drob's Avatar
    Aug 2010
    North Idaho
    78
    Quote Originally Posted by mga60tw View Post
    Yes. There is also this 'thicker' version:
    http://www.amazon.com/DuPont-Teflon-...4977430&sr=1-2
    http://www.webbikeworld.com/t2/motor...n-chain-saver/
    I bought both the blue and the yellow and at least my can of yellow is exactly the same consistency as the blue...
    - 2004 TW200 - Jimbo's Shield - Ricochet plate - Cyclerack - SoftBottom pad - wide pegs - siderack for saddlebags - RotoPax - Maxxis 6006 tire
    Aug 2010
    10
    Thank you!
    Moderator vuldub's Avatar
    Aug 2010
    Calgary, AB Canada
    652
    There was a comment on using carb cleaner on the chain - if you have an oring chain, carb cleaner will dissolve the rubber orings so DON'T use carb cleaner.
    Take the chain off an soak it overnight in varsol or solvent. Scrub gently with a toothbrush.
    If you have an oring chain you can buy a spray that is light enough it penetrate in behind the orings. If it's not an oring you can use a thicker formula spray or even oil. But wet lubes attract dirt so some don't like them. I offroad in the mud and spray off the chain after each ride, let it dry, then apply a spray lube. That keeps it well lubricated in the dirt (kind of hard not to attract dirt when you are knee deep in mud....) and keeps the rust away. But I do this each trip and wash down after so I don't mind a greasy messy chain (arr arrgh).
    Regards...Wes
    Aug 2010
    10
    Great advice!
    Aug 2010
    10
    I probably need a new chain very soon. What about the DID product?
  1. Looking for an early frame with clean title! Will pay$$
    By Withoutwings in forum TW200 Classifieds
    Last Post: 04-20-2013, 10:15 PM
  2. 1995 carb clean/tune
    By Bucknutz in forum Performance and Customization
    Last Post: 03-11-2013, 02:26 PM
  3. What do you use to clean & oil your air filter?
    Last Post: 11-02-2012, 10:00 AM
  4. Lube price hikes
    By Xracer in forum General Discussion
    Last Post: 08-24-2011, 02:22 PM
  5. Tire Lube
    By Rainman in forum Technical Help
    Last Post: 12-25-2010, 11:00 PM
deep creep seafoam o rings chain
dr 650 drive chain clean and lube
how to clean the chain on tw200
is deep creep good to use on o ring chains
lubrication tw200
tw 200 chain cleaning
tw200 chain lube
tw200 chain lube miles
tw200 forum anyone using dry chain lube
what do you use to lubr the drive chain on your dr650
yamaha tw200 chain lube
yamaha tw200 how to lube chain motorcycle
