kickstart and oil cooler installed
Results 1 to 10 of 15
    Member 6Z37RLC's Avatar
    Jun 2011
    vancouver island bc
    94
    I finally got the kickstart installed as well as oil cooler. The lizsrd cooler adapter installed nicely behind my side guard, thanks Russ nice job on the oil filter cover. I made the cooler out of billet aluminum left overs from the scrap yard. The location might be a little exposed will see how that plays out, I drilled six channels three up three down and had the fittings at the bottom. The plate on the side of the cooler will do three things, protect the cooler if the bike has a lay down, help draw more air through the cooling fins and direct more air on the hottest part of the engine even at slow to moderate speeds. Initial air gun testing in the shop indicates the air stream will hit the front corner of the engine, installing a temp gauge and have to do some riding to test all this theory out.
    Island-Tduber
    Desert, SoCal
    7,369
    Wow. That thing is BUILT, just like all your stuff.
    Nice work.
    Jun 2011
    vancouver island bc
    94
    Nice work.
    Thanks Russ. I got one cooler hose about 5/8" from the exhaust pipe can I get away with that or should I be looking at some shielding?
    Island-Tduber
    Tennessee
    1,286
    Quote Originally Posted by Island T-Dubr View Post
    At that close it might be iffy, especially sitting still. You probably wouldn't have much trouble finding steel braided hose that'll fit.
    That setup looks awesome though. I'll have to copy that someday or something.
    Desert, SoCal
    7,369
    I've been running the goodguy 5/16" Gates hose for about 1,500 miles so far without the slightest indication that it won't last indefinitely. The return line is probably within a half inch of the lower front loop of the header. I shared your concerns at first and this installation was only intended as an an expedient during prototyping, but I'd run it permanently at this point.
    Additionally, these hoses have been on and off the bike at least a dozen times at this point and they still lock onto the fitting barbs like they did on Day 1. Tighten the clamps a bit and ride away.
    The Cali option puts the cooler a bit lower, but as you've probably discovered the higher your cooler fittings the more direct are your options for routing the lines. The Cali bikes have a convenient loop on the front motor mount which formerly held the canister drain line and now holds the return line a perfect distance from the exhaust. As long as there's no risk of direct contact due to movement I think you're safe at 5/8".
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    Boy, some real nice work T-Dubr; the cooler looks super as does your case guard. Gerry
    Take care my Friend.........
    Senior Member joedirt1970's Avatar
    Cardiff by the Sea, CA
    1,345
    Looks great. None of the big 4 stand a chance to do a better job.
    Hidden Content [/IMG]It's not why, but why not. Do it for the right reason now, versus the wrong reason later.
    Born on a Honda Z50, '78 YZ 80, '79 Husky WR 250
    2008 TDub--Jimbo Shield, Lizard Oil Cooler, Blaster Shock, YZ Hybrid Forks, Supermoto front fender, ATV Bars, Acerbis Brake Cover, 1460 Pelican Case, Cycle Rack, Power Core, Gold Chain.
    Jun 2011
    vancouver island bc
    94
    Thanks Guys
    I found working on the tw after supper the wife is happier she gets to watch all her programs on tv
    Island-Tduber
    Mar 2011
    Gobles, michigan
    1,824
    Thanks Guys
    The U.S. army tried calling you, they are looking for some missing M-1 tank parts !!!!!!!! Nice "SOLID" looking dub. OMM>
    Jun 2011
    vancouver island bc
    94
    Quote Originally Posted by omm View Post
    Thanks OMM I was always fond of heavy metal
    Island-Tduber
  1. Kick start case on non-kickstart engine
    By Idaho04 in forum Performance and Customization
    Last Post: 07-17-2013, 06:46 AM
  2. Bending an aluminum kickstart... ?????
    By zardoz in forum Performance and Customization
    Last Post: 10-04-2012, 09:10 AM
  3. ProCycle Hi-Fender Installed.
    By Wingnut in forum Performance and Customization
    Last Post: 09-18-2012, 04:58 PM
  4. Clutch fixed, now Kickstart problems!
    By SCARE! in forum Technical Help
    Last Post: 08-30-2012, 04:23 PM
  5. Broken kickstart retention clip wall
    By sakogu in forum Technical Help
    Last Post: 07-21-2012, 05:34 AM
