led spot flood lights
Results 1 to 10 of 19
    Member 6Z37RLC's Avatar
    Jun 2011
    vancouver island bc
    94
    I want to put a couple of led spot flood lights on above the headlight on either side. Want to be able switch headlight off and leds on and not have both on together. The lights are 27w each,and will be off a relay, will this be asking for trouble as far as balance and wattage?
    Island-Tduber
    Senior Member emilliano's Avatar
    Jan 2011
    USVI
    202
    where did you get the lights ?
    [email protected]
    Jun 2011
    vancouver island bc
    94
    Quote Originally Posted by emillio View Post
    [email protected]
    I got them off ebay there are a number of different sellers.
    Island-Tduber
    Desert, SoCal
    7,369
    I don't see an issue. The stocker is 65W, 52 is close enough.
    Actually, the stocker is 55w on low, 60w on high. I'd wire a double throw switch into the hot wire leading to the dimmer switch. Flip one way, headlight works normally. Flip the other way, LEDs come one. In the middle, all off for a hotter engine crank when starting.
    Jun 2011
    vancouver island bc
    94
    Thanks for confirming its doable.
    Ron
    Island-Tduber
    Jun 2011
    vancouver island bc
    94
    qwerty thats what I had in mind only better with switching both off for starting, thanks for the instruction.
    Ron
    Island-Tduber
    With a double throw switch there are 3 positions: circuit 1--off--circuit 2.The turn signal switch is of this type.
    More specifically, you want what is called a Single Pole Double throw switch. There will be three contacts on the back, usually two of one color and the 3rd a different color. Connect the hot wire to the odd color. Connect each of the light circuits to one of the terminals of the shared color. Off will be in the middle.
    Autocraft Part No. 85919/85919 goes for about $5. No panel, wires or waterproofing included.
    For ease of mounting and a reasonably weatherproof installation, I'd hunt around for a universal motorcycle headlight switch with off, low bean, and high beam positions. These mount with a screw or two on any 7/8-inch pipe, say, like the handlebars. Maybe hunt around the dualsport light kits for dirt bikes. You can get these switches combined with other switches in the same housing for controlling multiple accessories. I've used the K&S Technologies Part Number 12-0051 on p[rojects before. Cost about $35, and money well spent for the convenience and weatherproofing. It's only rated for 2 amps so you'll want to wire relays with 14 gauge on the switched ciruits.
    Jun 2011
    vancouver island bc
    94
    This will make it easier thanks for the info.
    Ron
    Island-Tduber
    len
    len is offline
    Junior Member len's Avatar
    Jul 2012
    11
    Island, I have the same set of LEDs on order that I was hoping to replace the stock headlight with. Have you had the lights plugged in yet? Would you be able to comment if the lights are bright enough to replace the stocker? Any beamshots you could share?
    Let us know, thank you!
  1. Looking for advice SPOT
    By Johninaz in forum Trails, Off-road, and Adventure Riding
    Last Post: 06-17-2013, 06:26 PM
  2. milking the most from my Spot options
    By peruano in forum Trails, Off-road, and Adventure Riding
    Last Post: 08-07-2012, 10:05 PM
  3. ATT. SPOT Owners
    By kj7687 in forum General Discussion
    Last Post: 04-02-2012, 11:45 PM
  4. Spot GPS Messenger $55
    By Larry in forum Performance and Customization
    Last Post: 08-19-2011, 07:10 PM
  5. Anybody doing the WI/MN Flood Run this year?
    By Schleppy in forum General Discussion
    Last Post: 04-06-2011, 10:59 AM
