Cornshield Engine Rebuild
Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 112
Like Tree538Likes
Thread: Cornshield Engine Rebuild
    Senior Member Cornelis's Avatar
    Mar 2015
    Centurion, South Africa
    589
    Cool Cornshield Engine Rebuild
    I really don't want to do this right now, my bike was running SO well commuting with her daily all over the place without any problems at all
    Unfortunately she was just burning too much oil for me to continue riding so I took off the engine today and I want to open it tomorrow.
    As you can see I have the full range of special tools for the job . . . .
    New 70 mm oversize piston and rings to be installed, I don't need to split the gearbox because it is still in a good condition
    I will post the photo's of the inside of the engine tomorrow
    admiral, littletommy, Fred and 9 others like this.
    1990 Yamaha TW200Hidden Content _____________ Come to Me, all you who are weary and burdened, and I will give you rest. - Matthew 11:28
    Mar 2015
    Ynys Môn
    4,630
    The one in the middle seems about right ....
    - Hidden Content
    Senior Member Elvesus's Avatar
    Jun 2015
    Nanaimo BC
    311
    Good luck Cornelis!
    littletommy, Cornelis, Ken and 1 others like this.
    John in Nanaimo
    2013 TW200 - with Shinko 241 front tire, Rox 2" anti-vibe risers, Polisport Touquet handguards, homemade wind deflector, Manracks utility rack
    Frosty Hollow
    13,169
    For some reason, I'm drawn to your toolset. Too bad you have to use it. I hope the operation is successful Dr. Cornelis.
    19,019
    Title had me worried you had suffered a disaster. Nice you are just hammering out some timely maintenance before something serious happened. Now might be a good time to get sealed bearings for the swing arm to avoid any assembly difficulties. Otherwise it can be a challenge getting all the factory bushing seals and swing arm aligned with the frame holes while inserting the pivot bolt.
    Mar 2015
    589
    Thank you for your encouraging words everyone and I want to let you all know that at least I'm not left by myself but I have a biker friend who offered to help me with the rebuild.
    His name is Gavin and this guy has a double garage with 9 bikes with 6 up and running and 3 in various stages of rebuilding, he's a real biker to the bone.
    Whenever he's got some spare time he is working and tuning one of his bikes
    His latest project is the rebuilding of a Kawasaki ZX11 Turbo
    admiral, littletommy, Fred and 7 others like this.
    May 2013
    Groton, NY
    2,663
    A wide selection of "UAT"s.... Universal Adjusting Tools.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,957
    How many miles did you have on it before the rebuild? What oil and weight did you usually use? Are you going to put a bigger cam and valves while you have it apart? Good luck with your rebuild.
    Mar 2015
    Ynys Môn
    4,630
    What you need to do, is to anchor one side of the rear frame to a fixed point, and attach the other end to the back end of the ZX11 — then, while the Kwack pulls the two bits apart, you need to get under there with the relevant parts of the swinging arm assembled, (with said lump hammer in hand), while a third person bounces up and down on the seat
    With a bit of practice (and a significant amount of tire smoke), eventually the clutch on the Kwack will give up the ghost - and at exactly that moment, (if you’ve timed it right), that last smack of the hammer will seal the deal
    Your friend may go through a few bikes trying this method — but hey — that’s what are friends for ……
    - Hidden Content
    Nov 2010
    Frostbite Falls Ill
    2,719
    The tool in the middle is for adjusting Harley valves and ignition timing.
    Phelonius
  1. Looking for someone to hire to rebuild an engine or 2
    By Skin Walker in forum TW200 Classifieds
    Last Post: 01-29-2017, 08:48 AM
  2. Tw engine rebuild
    By DEUCE32 in forum Technical Help
    Last Post: 02-07-2016, 01:08 PM
  3. When do you rebuild an engine?
    By nunya in forum Technical Help
    Last Post: 11-02-2014, 02:17 PM
  4. Time to rebuild the Engine
    By admiral in forum Technical Help
    Last Post: 09-10-2014, 10:34 AM
  5. Engine rebuild and diabetes
    By WINGNUT200 in forum Off-Topic
    Last Post: 04-05-2011, 08:37 PM
news
tw200 engine rebuild
