Jetting for 10k feet
Results 1 to 8 of 8
    Member -Jake-'s Avatar
    Feb 2012
    81
    Plan on going elk hunting to Colorado in October. Currently my 2000 TW is 100% stock and runs good here at 900 ft above sea level. We took my dad's 200 cc 4 wheeler a couple of years ago and it wouldn't run good enough to pull a hill with you on it. I want to avoid that with the t-dub. So I assume I only need to change the main jet but to what size? thanks!
    Senior Member bcscammell's Avatar
    Oct 2011
    264
    There is only one way to find out and that is to try your bike at those elavations with different jets. The higher you go the leaner you need to go on the jets. There is a product called dial-a- jet which is an adjustable (jet) that adds more fuel when required. If you run your bike at 10,000 feet you would put in a lean main jet that runs good at that elavation and when at lower elavations you adjust the dial-a- jet to richen the mix. I haven't used one because I don't see those kind of elavation changes but the idea seems to make sense. Here is the link . http://www.thunderproducts.com/dial_a_jet.htm
    Feb 2012
    81
    Not interested in spending that much coin. I could buy 2 jets of every size for that price! lol, thanks though. I think I'll probably just pack several different sizes.
    Oct 2011
    264
    I never looked up the price but you're right, they are expensive. I guess if you were riding from sea level to 10,000 feet on a weekly basis it might be worth
    it. There are some folks on the forum that suggeted drilling holes in the air box and plugging them by some means until you reach higher elavations. By
    removing the plugs there is more air available to lean out the mix. The higher you go the more plugs you remove. Haven't tried this either but it also makes sense. Good luck on the Elk hunting trip.
    Junior Member kgriff's Avatar
    Apr 2012
    26
    Mine's a stock '96. I live at 5,000 ft. and have had it, so far, as high as 8,500 ft. and it's run fine. Next trip I should be going higher and I'll report back how it does. Of course, yours may do different, so I wouldn't hesitate to carry some jets along.
    On a side note, where are you hunting?
    Feb 2012
    81
    Quote Originally Posted by kgriff View Post
    Thanks, let us know! We will be hunting near Gunnison. We will probably go as high as 12k feet unless there is a lot of snow.
    Apr 2011
    Martinsville Indiana
    2,089
    You hunting up by crested butte? My 98 has the same carb your does and it made it over 13,100'"imogene pass" but it sputtered past 9,500. Might go a few sizes smaller. I
    Feb 2012
    81
    Quote Originally Posted by Small's View Post
    Cannibal Plateau
  1. Teikei @ 8-9,000 feet.
    By trailscout in forum Technical Help
    Last Post: 07-18-2013, 08:53 AM
  2. Customizing my feet
    Last Post: 02-05-2013, 10:28 PM
  3. carb jetting
    By niqhowie in forum Technical Help
    Last Post: 10-23-2012, 05:57 PM
  4. Stock jetting at 9000 feet?
    By DonBenito in forum Technical Help
    Last Post: 07-25-2012, 10:26 PM
  5. Exhaust and jetting
    By 530-TW in forum Performance and Customization
    Last Post: 05-15-2011, 10:34 AM
what size jetting for my 06 tw200 at 10000 ft
