LED Headlight Kit
Page 1 of 11 123 ... LastLast
Results 1 to 10 of 104
Like Tree268Likes
Thread: LED Headlight Kit
    Member JNS Engineering's Avatar
    Feb 2016
    58
    LED Headlight Kit
    I've adapted this modern LED headlight to the TW200. It's a plug and play kit. More details soon!
    Premium Dual-Sport Accessories
    Member turbodieseli4i6's Avatar
    Oct 2013
    SW Missouri
    99
    I can't wait to see how this works on the DR. The DR and TW could definitely benefit from the wattage savings.
    Feb 2016
    58
    The kit is now available for pre-order on my website.
    I also made this dorky video.
    Nov 2011
    norcal nutjob
    3,276
    that sure seems to pump out some light!
    would it work with pre-2001 bikes?
    how many watt is it?
    is the video demonstrating high and low beam?
    DOT legal?
    looks to be a great upgrade to the weak stock headlight.
    Senior Member putt-putt's Avatar
    Oct 2017
    Vancouver Island
    221
    I tried to pull the trigger on this but the site does not ship to Canada........
    How do we work around this?
    putt-putt
    Junior Member stevebpnw's Avatar
    Jul 2017
    19
    Quote Originally Posted by joeband View Post
    DOT legal?.
    yeah, "me too."
    JNS Engineering Yamaha TW200 LED Headlight Kit
    --Steve
    Feb 2016
    58
    Yes, this kit will work with all years of TW200.
    The video shows both the low beam and high beam.
    The low beam has two 10W LED/projectors (left and right) and one 15W LED/projector for the high beam (center). The low beam stays on when the high beam is powered. So that's 20W on low beam and 35W on high beam. The manufacturer claims the following specs, not huge lumen numbers but easily twice the output of the stock headlight and at a lower amperage (leaving more watts available for aux. lights, grip heaters, etc).
    Low: 1,100 Lumens
    High: 1,800 Lumens
    Color Temperature: 6000k
    Lifespan: 50,000 Hours
    No DOT approval due to an optional daytime running light that glows red. It is wired separately so it will only function if you go out of your way to wire it to a 12V source.
    Feb 2016
    58
    That's strange. I've received a few international orders this weekend without issue. Maybe try refreshing your browser?
    You can always call me and order over the phone. We could also go through PayPal or personal check.
    John
    (503) 480-4695
    Quote Originally Posted by putt-putt View Post
    Oct 2017
    Vancouver Island
    221
    Hi John, I sent you an email visas the your site. I was still unable to make it work so I sent you my info to calculate the shipping and to email me an invoice via PayPal.
    Thanks John!
    putt-putt
    Oct 2013
    SW Missouri
    99
    Quote Originally Posted by JNS Engineering View Post
    Low: 1,100 Lumens
    High: 1,800 Lumens
    I would rather have a low lumen light that puts all the light on the road where I need it, than a high lumen light that scatters it everywhere but the road.
  1. LED Headlight
    By tomushh in forum Technical Help
    Last Post: 11-20-2017, 11:48 AM
  2. LED Headlight?
    By Jduncan740 in forum Technical Help
    Last Post: 10-09-2017, 01:01 AM
  3. Inexpensive LED Headlight
    By Zoart in forum Technical Help
    Last Post: 01-08-2015, 11:06 AM
  4. LED Headlight Conversion
    By turbodieseli4i6 in forum Performance and Customization
    Last Post: 04-26-2014, 07:38 PM
  5. GE LED headlight....
    By wbpolk in forum Performance and Customization
    Last Post: 02-28-2014, 09:07 AM
jns engineering yamaha tw200 led headlight kit
led headlight for tw 200
news
tw200 high beam watt
tw200 led headlamp
tw200 led headlight
yamaha tw200 headlight wire colors
