I GOT THE POWER...
Results 1 to 3 of 3
    Senior Member Retrofit's Avatar
    Mar 2011
    Simi Valley So Calif.
    395
    In a previous thread i posted about an ebay "buy now" where you get a complete power adapt kit for about $20 bucks.
    it included a female socket with cap, connector rubber like vinyl boot, 42 in. fused wiring harness and a black rubber socket mount
    Although Im not exactly thrilled with the mount as the outlet is only pressed in and not permanently attached, the seller offered to switch it out for something else he had but i got lazy, figured it worked good enough for now and installed as purchased.
    The wire harness couldn't have been a more perfect length.
    Total time was 20 minutes to install and cost 20 bucks. Why cant all bike mods be this easy?
    removed the seat and tank, total 3 bolts and two fuel hoses (once for the cali tank)
    routed wires along side of existing bike harness using the stock wire holders and ties - assume a preschooler could have done this. (i have since rerounted the wire UNDER the frame)
    tried a few places on the bar, including front and rear, left and right. finally selected this one due to it's closeness to the GPS mount. hooked to battery, on the postive side, i managed to slide the connector thru the boot along side of the primary wire so that everything is protected as if it was stock.
    that night i was out riding, stopped to make a call... phone battery dead. got charge from trunk, put the phone in a place so it woudnt fall while it charged enough to turn on... few minutes later, phone call made, and back on road.
    guess in need one more ram mount on the bar! Now thinking about how to place one in the trunk to charge items that I dont want hanging from the bar.
    The Southwest
    566
    Nice.
    An outlet in the trunk would be a good idea.
    Senior Member Loppy's Avatar
    Aug 2012
    Fair Oaks, NorCal
    115
    Ha... I bought the same one and mounted it in almost exactly the same place. Works great.
    Those who forge their swords into plows, will plow for those who do not.
  1. no power
    By greendub in forum Technical Help
    Last Post: 07-12-2013, 08:16 AM
  2. Ultimate TW Power Mod
    By admiral in forum Performance and Customization
    Last Post: 11-23-2012, 01:49 PM
  3. Would like a little more power
    By Mizzoolian in forum Performance and Customization
    Last Post: 09-13-2012, 10:32 PM
  4. Power and Top End Upgrade
    By JD_ in forum General Discussion
    Last Post: 09-03-2012, 07:24 AM
  5. No power
    By bschauffler in forum Technical Help
    Last Post: 08-27-2010, 09:07 AM
