Duro Power Grip V2 Anybody Running This in the 27x9x14" Version on a TW ?
Results 1 to 9 of 9
Like Tree9Likes
  • 1 Post By PlacerLode
  • 1 Post By Fred
  • 1 Post By TW-Brian
  • 2 Post By jb882
  • 2 Post By Thetrainer
Thread: Duro Power Grip V2 Anybody Running This in the 27x9x14" Version on a TW ?
    Apr 2012
    Out West
    3,014
    I know TWBrian is running the 12" version (26-9-12") of this on his 2007 trailer wheel conversion but I was wondering if anybody has used this in the 14" rim version (27-9-14") on the OEM TW wheel ?
    I have a 3" extension on the TW I plan to use this on I'm just wondering about the overall height and if that is going to be an issue
    BTW if anybody has a scrap Duro or any other ATV tire used on a TW I'd love to see a cross section of the bead area (cut with sawsall) so I can see exactly what I'm dealing with when "trimming" the beads
    I have a brand new Duro and a few other ATV tires I got from TWilight I have been tempted to cut in half but they are all brand new so it would be a waste
    ejfranz likes this.
    "It's Like Warm Apple Pie"
    18,561
    Nine inch width might make for a tight fit on a stock swing arm but your 3" should be fine. If not trim you side tread bars. You can always try trimming Russian style.
    Reminds me of early days of Bighorn and Bighorn II ATV tire installations stimulating discussions for need of swingers extensions to gain width and length clearances. Did not Ronneydog have that size but in a Bighorn II?
    A 3 inch extension will increase your suspension travel proportionally, say 7 inches just for discussion. Should bike have this 7 inches of clearance when swing arm is fully extended then no problem. Clearance might become issue with rear sub-fender/taillight assembly since tire is 3 inches to the rear and travels further in an upwards arc than stock.
    I would suggest a 60 tooth rear sprocket for gearing compensation as well as to overcome all that rotational inertia from the tall, heavier tire.
    Either way there should be a significant increase in flywheel/ gyroscope effect compared to stock and will really help maintaining momentum over rocky ledges, logs and other obstacles.
    PlacerLode likes this.
    Apr 2012
    Out West
    3,014
    what the hell is Igor doing in that video other than trying to shear off his arms at the elbow ?
    westcoasting likes this.
    Frosty Hollow
    12,974
    I think a 27” will be to tall and not allow much chain adjustment without an extended swing arm. My 26x9 Ceros is pretty tight width and height wise.
    Apr 2012
    Out West
    3,014
    3" swing arm extension and Red ProCycle rear spring as well as ProCycle front springs
    admiral likes this.
    Apr 2012
    Out West
    3,014
    I was planning to sell the 3" extended swingarm thinking it's 1" too long but with this 27" ATV tire it might be perfect as long as the tire is not too wide
    Pleasanton, CA
    5,670
    Quote Originally Posted by PlacerLode View Post
    If you are successful getting the 27x9x14 Duro V2 mounted, it will fit in your 3" extended swingarm. The width will be close and you may need to remove or bend the forward lower chain guard bracket on the left side of the swingarm.
    Senior Member jb882's Avatar
    Aug 2013
    1,375
    I don't have a scrap one but on this page there is a video that i put together that shows how i trimmed mine on a scrap tire i had kicking around.
    https://tw200forum.com/forum/performa...d-today-3.html
    Fred and PlacerLode like this.
    Junior Member Thetrainer's Avatar
    Jan 2016
    North East
    28
    I am running that tire on a stock rim. Fits fine there was enough clearance between the tire and the swingarm.
    PlacerLode and Fred like this.
    87 TW200 w/ TRI-z front end
    86 GL1200
    1850 Hydra Sport
    past:
    89 TW
    90 TW
    86 BW200
    GSXR
    Xj750
    Ninja1000
    Z50
    etc....
  1. Blew up my new duro power grip :(
    By ShaggyAnt in forum Performance and Customization
    Last Post: 04-16-2019, 01:34 AM
  2. Duro power grip, and the legality of running in on the road....
    By Spawner in forum Performance and Customization
    Last Post: 04-04-2017, 11:25 PM
  3. Duro power grip install.
    By ZDR1 in forum Performance and Customization
    Last Post: 07-03-2015, 08:24 PM
  4. Duro Power Grip
    By trailscout in forum TW200 Classifieds
    Last Post: 12-19-2013, 12:25 PM
  5. Duro Power Grip Woes
    By Ben The Adventurer in forum Performance and Customization
    Last Post: 10-25-2013, 06:38 AM
