Well I have a the larger of the two sizes of 244 now and find when it's close to or below freezing I loose traction due to the hard rubber compound. Otherwise it is a great tire in most conditions. Now the 241 has such a softer rubber that I think it will perform better in colder weather. The tread pattern looks like it will grip even better since the lug to space ratio is 50/50. Plus the slits in the lugs make then extra flexible. I plan to put it on next weekend if all goes well but I'm not sure if I want to brave the cold/snow/ice out and there. I plan to stud the stock tire for real winter driving eventually.
Connect With Us
