Cycleracks Bag Supports
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    The Southwest
    566
    The Cycleracks bag supports came today as well. I thought I'd throw a pic or two of these up also.
    I did not know this, but Don says these bag supports are designed to work on the front rack too.
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    Those are great, you'll like them. I mounted a pair of 50 cal ammo cans to mine.
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Another member used clear tubing on the loops to keep the paint from grinding together.
    Cut four pieces to length, then I believe he boiled them (?) to get them soft enough to go on easy.
    I'm gonna have to start saving up for a rack & set of these.
    Stephen S.
    '07 TW200:
    Member ridgeline's Avatar
    Jun 2012
    dartmouth nova scotia 2010 tw200
    84
    i got the same rack i was thinking of getting a set of those for my bike would like to see a picture of what you decide to put on them
    The Southwest
    566
    Srs, I saw that about the clear tubing too. I was thinking I'd run down to the hardware store tomorrow and see what I can find.
    Ridgeline, I'm on the fence about how I'm going to use these. I have a Kolpin gas can on order so I'm going to see what that looks like on these. Don at Cycleracks says guys have put the gas cans on these supports and hung them off the front rack. I don't have a front rack, but I wonder what that would look like and how it would affect the handling, if at all. I'm also looking for a rifle boot that I may try and mount on one of them. And I'm looking for something that'll work as soft panniers, like molle packs. I wish I was one of those guys that could think of something and then just see it in my head, but that's not me. Anyway, I'll post up as I try different things.
    Smyrna, GA, USA
    1,417
    They look like (at least on the left) there is room to mount a tool-tube on the inside of the plate.
    Maybe even two on the left and one low on the right (below the muffler). Or a tube on the right and a fuel pack on the left.
    Then just drape soft bags over them, or mount hard boxes on the outside.
    I'm gonna search the forums for a pic of these from behind to get a better idea of how much room there is.
    While I definitely want a rear rack, I'm not gonna get a front rack until I find one that sits OVER the headlight so I can load it up and not block the light for road travel.
    Stephen S.
    '07 TW200:
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,516
    Quote Originally Posted by srs713 View Post
    SRS....my thoughts also on the front rack.....would be nice if Don would make one as suggested.Hmmmmm,if enough of us showed interest,maybe,just maybe Don would do it?.
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    Tool Tubes mount fine on top, without blockage - my bride commented that it looked like I had rocket launchers on it. I originally mounted them under the rack but moved them up just to see how they'd do. They work fine either place. I use my bike a lot around the ranch primarely during daylight hours - it's nice to slap a small chainsaw gas can and a container of chain oil on the front rack and my tools in my bags in back.
    Senior Member Rhodetrip's Avatar
    Aug 2010
    Out wandering around
    1,928
    Here's a picture of Mrs Trip's bike with seahorse cases mounted on the bag supports.
    "Me and Mrs Trip, we got a thing going on"... an on-going adventure...
    "When Piggies Fly" ...Me & Mrs Trip Cross the Pond
    "Take the Puppy to the Beach"...a dirt route across southern New England
    Latest Spotwalla: Hidden Content
    The Southwest
    566
    I did pick up some tubing. Two feet is enough for both sides. I bought the 1/2" OD (3/8" ID) stuff. It's too big. The next size down will be a heck of a fight getting it on, but it's probably the way to do it. This size leaves a gap between the tubing and the support. It'll just collect dirt. I wonder how heat-shrink tubing would hold up for this application? It'd be a heck of a lot easier to install.
    The Kolpin gas pack came today. The way Cycleracks has the supports pre-drilled, it's a bolt-on deal -- no drilling needed. I'll snap some pics tomorrow when it's light out and I'll pay special attention to the view from the rear so you can mentally measure for tool tubes.
  1. Cycleracks????????
    By Swamp in forum Technical Help
    Last Post: 05-25-2013, 07:29 PM
  2. Did the cycleracks change
    By Uwdlk2no2 in forum General Discussion
    Last Post: 04-27-2013, 08:08 PM
  3. Cycleracks bag supports *sold*
    By Rhodetrip in forum TW200 Classifieds
    Last Post: 03-20-2013, 12:11 PM
  4. Cycleracks
    By mtkd in forum General Discussion
    Last Post: 02-11-2013, 10:48 AM
  5. Cycleracks Installation
    By royalman in forum General Discussion
    Last Post: 07-10-2011, 05:55 PM
cucleracks bag supports
cycle racks bag supports
cyclerack bag support tw200
cycleracks bag support
cycleracks bag supports
cycleracks bag supports for crf250l
cycleracks pannier support review
luggage that fits with cyclerack
tw200 front rack
tw200 panniers
tw200 racks and bags
tw200 soft bags
