TW Lift Kit
Results 1 to 8 of 8
Like Tree20Likes
  • 2 Post By Thetrainer
  • 2 Post By Fred
  • 1 Post By Thetrainer
  • 4 Post By DougDotyTW200
  • 4 Post By Fred
  • 6 Post By TW-Brian
Thread: TW Lift Kit
    Junior Member Thetrainer's Avatar
    Jan 2016
    North East
    28
    TW Lift Kit
    Thanks to you guys on this forum I have renewed enthusiasm to complete this 87' TW project.
    I have stripped this down to only functional and necessary parts, no battery plastics etc.
    It has a TRI-Z front end with disc break, blaster rear shock with duro tire.
    Right now I have it running on a blue Chinese CDI and I am waiting for a forum member to build me a new CDI.
    Next up are some custom frame work, kick stand, headlight eventually paint.
    I have the pipe dream of getting it street legal in MA. Gonna need some DOT stamped parts and a title.
    If not I will just run it around some land we have and sell or trade it when I get bored.
    Thanks for reading feel free to give some feedback so I can keep the momentum going to finish up the project!
    Trail Woman and Heli-Mech like this.
    87 TW200 w/ TRI-z front end
    86 GL1200
    1850 Hydra Sport
    past:
    89 TW
    90 TW
    86 BW200
    GSXR
    Xj750
    Ninja1000
    Z50
    etc....
    19,023
    Massachusetts will have the following inspection checklist for motorcycle registration:
    • What do they inspect on my motorcycle?
      • VIN Number/Registration/License Plates
      • Tire and Wheels/Wheel Bearings
      • Axle Clamps/Cotter Pins
      • Brake Operation/Condition
      • Steering Head Bearings/Stops
      • Handlebars/Fork Tubes/Cables
      • Frame/Body/Fenders
      • Controls/Mirrors/Horn
      • Headlights/Headlight Aim
      • Turn Signals/4-Way Flashers
      • Tail Lamps/Brake Lights/ other Lighting Devices
      • Seating/Footrests
      • Fuel System/Engine/Battery/Exhaust/Excessive Noise
      • Swingarm/Shocks
      • Chain/Sprockets/Guard
      • Windshield/Cowling (if applicable)
      • Safety Bars/Luggage Racks
      • Sidecar (if applicable)
    While you won't have to worry about the sidecar a little investigation might help determine if the '87 is grandfathered from the four way emergency flasher requirement. Most states require a battery for the light & horn portion of the inspection.
    Jan 2016
    North East
    28
    Thanks Fred this is my punch-list so far.
    VT registration on the way
    !!! Non DOT tires problem
    Stock Rear front good working condition
    stock rear front needs caliper rebuild
    !!! missmashed head and fork bearings need kit
    2 in riser and aftermarket bars should be good new clutch cable
    Frame/Body/Fenders
    !!! looking for a front BW or Tri-z fender or custom setup, rear fender???
    I have a stock mirror and horn and extra wiring harness with stock controls
    Grandfathered in on 4way I have stock signals
    have stock parts
    Seating/Footrests
    chopped seat, larger rider pegs no passenger pegs
    New Petcock, Engine runs good, battery converted to capacitor kick-start only setup, have stock and aftermarket exhaust
    Swingarm/Shocks
    !!!Stock swingarm aftermarket shock (have stock rear shock)
    New Front sprocket 13Teeth, need to fab chain guard
    N/A
    N/A
    N/A
    Smitty Blackstone likes this.
    86 GL1200
    1850 Hydra Sport
    past:
    89 TW
    90 TW
    86 BW200
    GSXR
    Xj750
    Ninja1000
    Z50
    etc....
    Senior Member DougDotyTW200's Avatar
    Jan 2018
    Southern In.
    457
    Indiana requires about $20 and that is through the mail !!! I love fly over country
    2016, stock'ish and a 2003 Starting on a 225 or bigger 6 speed build as a spare for now and install later when done and ready on this bike.
    19,023
    Now that Staute of Limitations has expired I can admit to plating a KDX 2-stroke in Washington state via the trickery of a dry cell lantern battery hidden in my mailbag powering the lights and horn during inspection. What was easy then is likely criminal today. Massachusetts seems only moderately demanding.
    Pleasanton, CA
    5,780
    That's one good thing about California (at least for now) - no routine motorcycle inspections!
    Here's a 1999 Honda CR250 with a California street plate that I had for a while. It was a great hooligan bike but not all that practical for daily use.
    Jan 2016
    North East
    28
    I don't think I could get away with a 2 stroke on the busy streets of Northeast MA!
    TW-Brian likes this.
    86 GL1200
    1850 Hydra Sport
    past:
    89 TW
    90 TW
    86 BW200
    GSXR
    Xj750
    Ninja1000
    Z50
    etc....
    Jan 2016
    North East
    28
    I have a few mistakes on the build and I am learning as I go.
    The rear blaster shock put tons of slack in the chain, and when combined with a 13T front sprocket it is even worse. I did order a cheap chain tensioner it is the the way "slow boat from China"
    I did get a stainless allen bolt kit which will come come in handy when I have to take everything apart and return it to stock! I like the Stainless bolts looks good and way easier to use.
    I dropped a few lbs of bike weight when I replaced the battery with a large capacitor seems to work OK with the kick start and the headlight is fine also.
    Just waiting for the CDI to test the performance and see if getting this bike legally on the road will be worth the effort.
    86 GL1200
    1850 Hydra Sport
    past:
    89 TW
    90 TW
    86 BW200
    GSXR
    Xj750
    Ninja1000
    Z50
    etc....
  1. Using a jack/lift
    By revtbob in forum Technical Help
    Last Post: 03-18-2017, 08:43 AM
  2. Center bike lift/tranny lift?
    By Hidebound in forum Off-Topic
    Last Post: 07-07-2015, 09:51 AM
  3. New lift stand
    By Indiana in forum Off-Topic
    Last Post: 06-11-2015, 04:37 PM
  4. Replies: 6
    Last Post: 04-18-2015, 10:23 AM
  5. TW Adventure Kit + Plastics + Oil Cooler Kit
    By eldavo in forum TW200 Classifieds
    Last Post: 07-23-2012, 11:15 PM
tw200 lift
