IRC-GP1 1000 mile review
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By dganey
Thread: IRC-GP1 1000 mile review
    Senior Member dganey's Avatar
    Oct 2010
    SE Michigan
    341
    Just hit about 1000 miles on a 5.10 x 18 IRC GP1 on the front, and I thought I would post up. I bought the tire because the shinko 244 was out of stock in 5.10 at the time. The first 2300 miles was with the stocker. This is my experience and your riding style may vary results. I would say that my riding style ranges from casual to aggressive depending on mood/conditions. All miles with tire pressure at 18/18 front/rear. A real close 50/50 street/dirt use. The tire guy said it took .5 ounces to balance. He said I could have gotten away without any weights.
    Street: as good or better than stock--yes, a little heavier, slightly more resistance to turn, but that feeling was gone before the 1st ride was over. To me, the IRC feels more solid and planted and instils more confidence. The IRC is noted for not having some of the funky street manerisms of the Kenda in the turns. Disclaimer--I am not a peg dragger on the street and did not push either tire to its limit.
    Gravel: Noticable improvement over stock. Less front end sway and much more confidence in the turns.
    Sand: Noticable improvement over stock in light, medium, and heavy sand--we have lots in Northern Michigan. In fact, the IRC is so much better that I find I am much more relaxed and have less fatigue and arm pump from clenching the grips than I did with the stocker. I have also riden heavy sand single track that I tried many times and gave up on with the stocker. It will do it as long as your realistic about the TW and you ability. The nice thing about the TW with the IRC is that I dont have to race through the deeper sand single track to stay upright. Some hairy moments-yes, but it will do it, and I wouldn't with the stocker. The really cool thing about the IRC is that I can actually pick a line in the sand and ride it--well most of the time, it is sand after all. With the stocker, I was usually along for the ride.
    Hard Pack: Beter than stock. More solid and planted feeling.
    Other stuff (rocks, roots, wet, ect): Better than stock in all conditions.
    Front Braking: As good or better than stock on the street. Off-road: Notable improvement. There were many conditions I would not use my front brake in due to immediate front end washout. At fisrt, I was treating the IRC like the stocker when it came to braking off-road out of force of habit. When I grabbed the front brake out of necessity, I initially went oh no thinking the front end was going to wash compounding my problem. I was actually suprised that it did not. I now find myself using my front brake much more off-raod. (Please be careful and maintain reasonable expectations--all front tires can wash under braking)
    1000 Mile impression:
    Great wear so far. Other than the nibs, barely any wear. I have ridden the IRC harder than the stocker in all conditions (due to the increased confidence) and the stocker was more than half gone with notable sloping and vibration at 2100 miles. At this rate, the IRG will be around for a while. I am planning to run 16/18 or 16/16 pressure on my next trip next week to see how that works out.
    Will I buy it again--Probably not. Only because the performance of this tire so closely resembles the Shinko SR244 but costs twice as much. If the 244 were not available, I wouldn't buy any other tire than the IRC.
    Dusty
    Fred likes this.
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    Real nice review. This will help lots of folks out as a new front tire is one of the first mods I would suggest if someone likes to get off pavement. Thanks. Gerry
    Take care my Friend.........
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    I had them on my DRZ400 and was happy sorta WWII Jeep tire
    Ephrata, WA
    1,125
    Thanks for taking the time to write up your report. I'm sure it will help others in the future.
    1990 TW200
    Senior Member Adam-n-nevada's Avatar
    High Desert, Reno area in Nevada
    441
    I love my IRC! It is the best tire I've fitted to the front and has an excellent wear pattern - almost non-detectable.
    I've noticed it behaves more like the stock, but as you've indicated, with much more confidence with the sides biting a bit better.
    Glad you're happy with this!
    ...and, great review! I agree 100 percent!
    -Adam
    Senior Member Skyking's Avatar
    Nov 2011
    Frost, Texas
    572
    I wish they made one for our 14" rear tires. I'ld buy a set in a heartbeat.
    Ride on.
  1. Review Of My New Go Pro Hero 3
    By icpchad in forum Off-Topic
    Last Post: 12-08-2012, 08:30 AM
  2. 60,000 mile oil change
    By rm_hm in forum Off-Topic
    Last Post: 04-10-2012, 08:10 AM
  3. 95 TW200 $1000
    By PEEBALLS in forum TW200 Classifieds
    Last Post: 12-20-2011, 02:16 PM
  4. First 1000 miles
    By Hobopoet in forum General Discussion
    Last Post: 08-15-2011, 06:42 PM
  5. 600 mile service
    By bradbeer in forum Technical Help
    Last Post: 07-20-2011, 09:54 PM
air pressure irc gp 1
drz400 irc gp 1
irc gp 1 review
irc gp-1 review
irc gp-1 tw200
irc gp1 front review
irc gp1 review
irc gp1 single track
irc gp1 tire pressure
irc gp1 tires review
irc gp110 review
yamaha gp1 review
