Shock Replacement
Results 1 to 6 of 6
    Senior Member nfpgasmask's Avatar
    Nov 2010
    Reno, NV
    500
    OK guys, before you ask, yes, I did search, but what I am specifically trying to find, is a replacement shock for my 2009 TW that has a BLACK spring, not the lovely yellow spring it currently has. I thought my problem was solved simply by ordering one from Japan, which I did, only to find out that EMS will not ship a pressurized shock, even by surface mail. So, I think I need to find something here.
    Also, just so you know, I am building my bike up Japan style, in the end, my bike will end up looking similar to this one:
    So, as you can see, yellow doesn't quite fit! So, what options do we have here in the States for a stock spring replacement or a completely new shock with a black spring?
    I thought of painting or powder coating my current spring, but painting likely would not hold up, and I am not sure about powder coating a spring. Would the heat screw it up in some way?
    Thanks - Bart
    Desert, SoCal
    7,369
    AyersGarage is our resident powdercoat expert. Axe him.
    Springs are usually dipped in more conventional paints rather than being sprayed or powdercoated, but I there may be powdercoatings which flow at lower temps nowadays.
    Senior Member mrbracket's Avatar
    Jul 2012
    Springtucky, Orygun
    631
    Powder coating is basically a plastic coating. Powder coating can flex with the spring movement unlike most paints. Powder coating is baked on and heat can take the temper out of a spring. Most spring manufacturers recommend keeping the temperature of the spring below 400 degrees Fahrenheit when powder coating. Just tell your powder coat person to use a powder that can cure below 400 degrees, it will mean the part has to stay in the oven just a little longer.
    You've got a friend in the Bracket Business! Hidden Content
    Get your TW200 Parts at ProCycle! Hidden Content
    Nov 2010
    Reno, NV
    500
    Thanks, guys. Good info.
    Bart
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    The Yamaha V-Star spring/shock that I used had a black spring. If you have an extended swingarm I am not sure the spring would be stiff enough although it is more adjustable than the stock TW unit. I do not know year or model, you will need to gamble or research. Brackets needed to be extended for the V-Star unit to fit (length wise) the TW. Good luck. Gerry
    Take care my Friend.........
    Member 2goose's Avatar
    Oct 2010
    48
    Do a google search for "coil over springs"> HUndreds of spring rates, colors, etc.
    Bob
  1. Replacement Battery
    By wvbobsmith in forum Technical Help
    Last Post: 08-04-2013, 05:20 PM
  2. Chain replacement
    By sscooter in forum General Discussion
    Last Post: 07-14-2013, 09:21 AM
  3. Muffler Replacement
    By mra32 in forum Technical Help
    Last Post: 02-21-2013, 09:30 AM
  4. replacement mirrors
    By tw200_87 in forum Performance and Customization
    Last Post: 02-11-2013, 06:38 PM
  5. key replacement
    By gottoaz in forum General Discussion
    Last Post: 01-01-2011, 01:17 AM
15750654 shock
15750655 shock
15750655 shock specs
15750655 tw4
15750655tw4
cross 15750655 tw4
cross reference 15750655 tw4
shock 15750655
shock 15750655 tw4
shocks 15750655
tw 200 shock replacement
tw200 shock black
