Pegs
Results 1 to 7 of 7
Like Tree11Likes
  • 1 Post By dman33
  • 1 Post By Gulfrider
  • 3 Post By GCFishguy
  • 3 Post By Tweaker
  • 1 Post By Big Jim Swade
  • 1 Post By grewen
  • 1 Post By TopPredator
Thread: Pegs
    Member dman33's Avatar
    Sep 2017
    SOUTHEAST IDAHO
    49
    Pegs
    Was debating what to do about the mini stock pegs. I have in the past done the weld on extensions, not crazy about that, it takes time to do it right.. I looked at new pegs and there is a few that must be solid gold with black paint on them, but I found some on fleabay for like $12 with shipping I figured what have I got to lose..
    They fit good and the size is really just right, the springs suck and needed some custom adjustments but all in all they are pretty good.
    https://www.ebay.com/itm/Foot-Pegs-F...53.m2749.l2649
    littletommy likes this.
    DMAN
    TW200D
    HODAKAS, 950 KTM ADV, YAMAHAS
    "EVERY SOLUTION IS THE SEED OF THE NEXT PROBLEM"
    YOU CAN HAVE IT GOOD, FAST, OR CHEAP = PICK 2
    IF ITS GOOD AND FAST, ITS NOT CHEAP. IF ITS GOOD AND CHEAP ITS NOT FAST, IF ITS FAST AND CHEAP , ITS NOT GOOD.
    Senior Member Gulfrider's Avatar
    May 2014
    Florida Panhandle
    587
    A lot on here use those and the spring issue is very common but no issues. I like mine also.
    2005 TW200
    2007 Sportster 1200
    Senior Member GCFishguy's Avatar
    Oct 2016
    Moncton, New Brunswick, Canada ehh?
    343
    Those ones are one of the fairly popular choices for the TW's. I found them to feel very cheap, and likely so brittle that they'd break if they caught a good smack on a rock or something. BUT they're $14...AND I'd actually prefer the peg snap off or apart than it tear the mount, and possibly the frame all to hell. Buy 2 sets and keep a set as a spare, etc.
    Dec 2015
    San Diego
    1,865
    They seem to be holding up for a lot of guys. I have not heard any bad reports. Krator Amazon pegs supposed to be cast steel.
    Check post #27 about how I modded my pegs to get full rotation up by grinding. Pics there. I also needed to drill one in the right spot for the spring. I think the new ones may have both spring holes in the correct spot. Champer the pin for easier insertion.
    https://tw200forum.com/forum/performa...ot-pegs-3.html
    Junior Member Big Jim Swade's Avatar
    Sep 2017
    Central Idaho
    20
    I put Krator's on mine from Amazon. I think they were $22, you have to drill a new hole on one of them to make the stock spring work, but it wasn't a big deal. I had them both on in less than 30 min. I haven't ridden them yet. Waiting for sunny weather.
    2017 TW200
    Krator Pegs, Rear Cycle Rack
    Jimbo Shield 650 Miles on it.
    1962 Honda Cub 55
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,410
    i tried a pair of aftermarket pegs and for some reason the angle was wrong, just a little off but made them uncomfortable. so i just welded some 1" flat bar around the old ones and hit them with the grinder and everything was perfect. about $10 with paint
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Jun 2014
    Bel Air Maryland
    4,170
    Might as well go buy a longer shifter while your at it. Especially if you have big feet or your wearing MX boots.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
  1. Replies: 0
    Last Post: 09-01-2016, 08:59 PM
  2. My feet keep slipping off the pegs. Are oversized pegs a good idea or a hazard?
    By TacoMcNacho in forum Performance and Customization
    Last Post: 06-05-2015, 06:48 PM
  3. My new longer pegs
    By rivershot in forum Performance and Customization
    Last Post: 02-08-2015, 11:59 AM
  4. Ebay $13 wide pegs versus $80 IMS pegs
    By docjekyll2002 in forum Performance and Customization
    Last Post: 10-28-2014, 09:36 PM
  5. Replies: 8
    Last Post: 08-25-2014, 07:30 PM
