Bending an aluminum kickstart... ?????
Results 1 to 9 of 9
    Senior Member zardoz's Avatar
    Aug 2012
    Nova Scotia
    187
    OK folks I'm looking for your thoughts. Because my TW is customized with a yz250f engine there is a clearance issue with the kick start lever. The po/builder created a homemade lever that looks like shit and works pretty much like shit as well. If I use the kicker as it sits now I have to put some sort of bushing (a little over a 1/16 of an inch for a guess) behind it on the shaft or it still contacts the frame I've picked up a used lever for the engine for cheap and am ready to try and modify it. I need to bend the lever in a couple of spots to create the needed clearance... whats the best way to go about this? I'm leery of applying too much heat but don't know what other options might be available.
    I suppose I could create my own kicker like the builder did, tho I don't think I would use square tubing like he did. I've thought of roughing one up with solid round stock with my little crappy mig to get clearance correct then taking it to someone with some proper gear to weld it up right.
    OK go ahead and laugh at the homemade kicker... here it is
    If you were in this position what would you explore for options?
    z
    Full custom 2008 TW200/250 build pics of my bike... I call her TW (short for "Twice Wicked" for her almost doubled HP Hidden Content )
    Newest member of the herd... 1987 Honda CBX250... this bike will become a board tracker this summer
    Bought another bike last fall (2012) ... 1982 Kawasaki KZ305 it's a "mostly done" bobber project I got for practically nothing
    Jun 2012
    Southern Michigan
    269
    I would have a welder do it.
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    Quote Originally Posted by zardoz View Post
    . . . If you were in this position what would you explore for options?
    z
    Z,
    You can get the TW200 kick-start boss and it should be a simple attachment to your lever. You will have to study your lever and the TW200 lever to see if the additional offset provided by the TW boss will give you the necessary clearance. I have a post on that, which is included in the kick-start sticky - you might want to look there. Here is a photo of the XT225 boss next to the TW boss.
    Aluminum alloy doesn't take to heating and bending like steel does. It tends to reach a critical temp and then just slumps into a puddle. But your lever should be cast steel - mine is.
    Good luck!
    Aug 2012
    Nova Scotia
    187
    Quote Originally Posted by Bullspit View Post
    I'm leaning in this direction as well, I've considered making it a solid kicker without the joint. When you need to start the bike... slip the lever onto the shaft and kick the beast until it. Then stow it with clips/velcro under the seat.
    z
    Aug 2012
    Nova Scotia
    187
    Quote Originally Posted by Flingwing View Post
    Z,
    Good luck!
    Hmm I wasn't aware the TW has a steel kicker, the bike only came with the homemade pos. I'll have to check if the boss for the YZ uses the same splines as the TW, if it does it looks as tho it (the TW boss) has a significant offset compared to yz's offset. I'll check on the thread you suggested.. thanks for the heads up!
    z
    Aug 2012
    Nova Scotia
    187
    I'm concerned that the TW boss won't work. I notice that the TW boss and the XT boss are both held on with a "pinch bolt" whereas the YZ boss is slipped on and held with a allen head socket screw into the end of the shaft. It's a shame.. because it looks like the offset on the TW boss just might be enough.. I'm not afraid of adding a little bit of a "groove" in the kickstart shaft, I wouldn't have to remove very much material to allow the bolt to pass. I do need to know the dimension of the TW boss tho to see if it will rotate within allotted space on the YZ engine side cover.
    z
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    You can still use the TW slip on piece. If the splines are a match, slip it on to your engine. Use a vice-grip to clamp it to the motor shaft with just enough pressure to only snug enough to slip on and off with just a bit of resistance. Now with your welder, weld up that gap just enough to hold that dimension. Now you can use the allen bolt and a washer to hold the kicker arm in place. Just a thought. Gerry
    Take care my Friend.........
    Apr 2012
    374
    Quote Originally Posted by mrgizmow View Post
    Z,
    What Gerry said is right on and pretty easy to do. Just remember to grind a v-groove along the lot and clean off all the paint before you weld it shut. There is a fair amount of stress on that boss as you crank and you want as much weld penetration as you can get.
    Aug 2012
    Nova Scotia
    187
    Thanks for the advice and tips on the TW splined boss guys! I have a couple of new directions now and hopefully I can get this sorted out sooner rather than later. It never ceases to amaze me the level of ingenuity that's displayed on this forum, you guys and this forum ROCK!
    z
  1. Kick start case on non-kickstart engine
    By Idaho04 in forum Performance and Customization
    Last Post: 07-17-2013, 06:46 AM
  2. Clutch fixed, now Kickstart problems!
    By SCARE! in forum Technical Help
    Last Post: 08-30-2012, 04:23 PM
  3. kickstart and oil cooler installed
    By 6Z37RLC in forum Performance and Customization
    Last Post: 08-18-2012, 01:31 PM
  4. Broken kickstart retention clip wall
    By sakogu in forum Technical Help
    Last Post: 07-21-2012, 05:34 AM
  5. Small diameter pipe bending
    By gdcone in forum Technical Help
    Last Post: 10-13-2011, 08:34 PM
aluminum kickstarter is bent can i heat it up and bend it back
bend aluminum kick
bending a cast aluminum lever
bent kickstart lever
diy homemade kickstart lever fix
ducati kickstarter needs bending
heating and bending aluminum kickstart lever
homemade bobber fender aluminum
homemade kick start kawasaki
homemade kick start lever
how to bend aluminum kick startsr
kickstarter shaft bent
