Air filter subsiitute?
Results 1 to 10 of 11
Like Tree18Likes
Thread: Air filter subsiitute?
    Senior Member mrlmd's Avatar
    1,157
    Went to inspect my air filter today and it was totally dried out and mostly disintegrated, my bad for not looking at it more frequently. The metal screen behind it was partially clogged up and I vacuumed all the dried foam off it and cleaned it up.
    A replacement for a new one, basically a small thin sheet of foam cut to size, from an aftermarket vendor on either of the two auction sites is $7.50.
    While I don't violently object to paying an exorbitant price for something worth maybe $0.50, I really don't want to wait a week or more until it ships and arrives at my house as I want to ride the bike, and the price from the nearest dealer is over twice that which is ridiculous for what it is.
    Has anyone tried to use a ScotchBrite pad or similar? They come in different grades/colors, and I would use a fine one so as to catch more dirt. Maybe even two layers thick. Seems to me that would last a looong time compared to foam and could be easily cut to fit and oiled up just the same as a foam sheet air filter.
    Let me know what you think, if positive, I may try it and see how it works.
    Jul 2012
    Wet-ern Washington
    1,415
    Try a UNI...Amazon Prime http://amzn.to/2CWoXnF
    Gulfrider, Ken and littletommy like this.
    - Leisure Time Larry -
    Hailey, ID
    3,409
    ScotchBrite will NOT work! It is much too porous to the small particles that an air filter is designed to trap. Pay the dealer and call it a fine for not paying attention to your TW's maintenance needs .
    Fred, Peterb, Ken and 1 others like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    May 2013
    Groton, NY
    2,663
    I try to keep the intake and exhaust systems stock if possible. One little change can sometimes change the performance or starting characteristics and not always for the better, IMO.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,970
    I sure have thought about putting a Briggs and Stratton air filter in the square hole under the seat. They seem to last forever and they are made for really dusty environments. You can also get prefilters for them. I think getting the proper hp rated filter would be a necessity. Scotti158 brings up a good point though.
    scotti158 likes this.
    1,157
    OK. I'll invest in a new foam filter and this is the one I ordered in case anyone else needs one. It's supposed top arrive by Saturday next week and after I get it I'll let you know how it looks/works.
    https://www.ebay.com/itm/Yamaha-TW20...97.m4902.l9144
    littletommy and Gulfrider like this.
    19,073
    Wise decision mrimd. Seems like the heat and humidity of Florida is hard on our bikes and thus frequent servicing is waranteed.
    The UNI filter would have worked too, but was the last one . However installation was included at only $79.20.
    littletommy likes this.
    Hailey, ID
    3,409
    Looks to be OEM. I might also recommend that you try the NoToil filter oil and cleaner kit. The oil is extremely sticky and does not evaporate, catching even smaller particles than regular oil. The best part is that the cleaner allows you to clean the filter in a sink and air dry it, then add about three tablespoons of the oil, roll the filter to distribute, air dry 10 minutes and install. One kit will last about 5 years.
    I was still using the original foam filter on my 2010 after 7 years and 16,000 miles. This product is very gentle on the foam.
    littletommy and SpeedyTide like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member Pete H's Avatar
    Dec 2016
    Upstate NY
    107
    The stock foam is good if it's cared for properly, and $8 bucks is too much for anyone? Scotch brites will not work. Yamaha has rocket scientists who do nothing more than design proper filter material. To think that 3M can accidently improve on that to wash dishes is nutts. (a make shift holdover fix at best) Any grit that gets by is like sandpaper in a engine turning up to 9500 rpms. Precision machinery don't take well to grit.
    Member dman33's Avatar
    Sep 2017
    SOUTHEAST IDAHO
    49
    Talking about air filters this is a link to air filter real world testing I will never use a K&N on a dirt bike, or even a string trimmer for that matter.
    K&N Air Filter Review - Debunking the Myths (and why OEM is better)
    Tweaker likes this.
    DMAN
    TW200D
    HODAKAS, 950 KTM ADV, YAMAHAS
    "EVERY SOLUTION IS THE SEED OF THE NEXT PROBLEM"
    YOU CAN HAVE IT GOOD, FAST, OR CHEAP = PICK 2
    IF ITS GOOD AND FAST, ITS NOT CHEAP. IF ITS GOOD AND CHEAP ITS NOT FAST, IF ITS FAST AND CHEAP , ITS NOT GOOD.
  1. Now That's A Dirty Air Filter!
    By Fred in forum General Discussion
    Last Post: 09-25-2016, 12:36 PM
  2. It's all in the air filter!
    By kj7687 in forum Other Bikes
    Last Post: 08-05-2016, 02:15 AM
  3. TW air filter oil
    By Explorer in forum Technical Help
    Last Post: 09-12-2015, 04:15 PM
  4. Air Filter question
    By 2000TWThumper in forum Technical Help
    Last Post: 08-04-2014, 09:49 PM
  5. air filter modification - help
    By tokey in forum Performance and Customization
    Last Post: 06-06-2014, 06:47 AM
