320 brake disk kit - how's interesseted into it?
Page 1 of 11 123 ... LastLast
Results 1 to 10 of 108
Like Tree2Likes
Thread: 320 brake disk kit - how's interesseted into it?
    Germany, Werdau
    1,014
    Hello,
    maybe some from you has seen this topic NEW BRAKES !!!! from AFISHALBIZ about the 320 brake disk conversion.
    He was the first one from the US who as bought this brake disk kit.
    I've received 2 weeks ago a massage from a TW driver in Singapore, he also want to buy a 320 kit.
    But there is a problem, I don't have the adapters on stock.
    To make just one adapter is really expensive, so I have to make more than just one.
    My problem is, that I don't have the financial reserve to make some new.
    I have to make minimum 3 adapters to make no loss.
    It would be great, if 2 or 3 TW drivers from the US will also order a 320 kit from me.
    You can see here the different designs from the brake disk:
    std. disk .................................. wave disk .................................. teeth disk
    -> Click on the picture to get a bigger image. <-
    Buyer list:
    1. -TWdude26 from singaporebikes.com
    -> 2 more buyers needed to make TWdude26 happy.
    This kit will also fit on the Yamaha XG250 Tricker (was this bike also available in the US?).
    And it should also fit on the Yamaha XT225 and TTR230. These bikes does have the same brake disk diameter and I've seen a picture on the Yamaha website and it seems, that they have the same brake caliper.
    Oh, I think I should also write down the prices:
    - 95.91 EUR for the std. disk (instead of 104.13 EUR)
    - 99.01 EUR for the wave disk (instead of 107.22 EUR)
    - 99.01 EUR for the teeth disk (instead of 107.22 EUR)
    - 58.91 EUR for the adapter
    If there is a question, don't hesitate to ask me.
    Regards, Sebastian
    jvt
    jvt is offline
    Senior Member jvt's Avatar
    Enumclaw,washington
    136
    The rear disk has been done . A kit may be handy. this is an old post one how it was done.
    jim
    https://tw200forum.com/forums/29748/ShowPost.aspx
    Germany, Werdau
    1,014
    This kit is for the front wheel, not for the rear.
    Senior Member mrbracket's Avatar
    Jul 2012
    Springtucky, Orygun
    631
    Excellent work macbig2k1 !! I have a drum brake model, but I really like what you've done!
    You've got a friend in the Bracket Business! Hidden Content
    Get your TW200 Parts at ProCycle! Hidden Content
    Germany, Werdau
    1,014
    It would be an interesting job, to make a adapter to convert a drum brake model to a disk brake model without changing the fork tube and the front hub.
    Back to topic.
    Who else (with a disk brake model) is interested?
    Sebastian
    Senior Member randucci's Avatar
    Mar 2012
    Seattle, Wa.
    134
    Can you post a picture that is much closer so we can see what is involved in making the conversion? I see only two prices for three different discs, are the two on the right side the same price? Are you willing to share what bike the discs are originally made for?
    Germany, Werdau
    1,014
    Np problem, here is the picture:
    I've changed the first post a little bit.
    Now there is a short description under the disk designs and 3 prices for 3 disks.
    These disks are originally for the TW!!!!!!
    They are direct made for the TW!!!
    I've send the needed measurements to the factory and they make the disk for me.
    This disk will also fit on the XT250, but this bike will need a other adapter.
    Mar 2012
    Seattle, Wa.
    134
    Quote Originally Posted by macbig2k1 View Post
    Thanks for the added information. Are all three discs the same diameter and the pictures just make #2 and #3 look smaller or is #2 & #3 a smaller diameter? What material are the discs made from? Can just the disc be purchased and not the adapter? Thanks.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,516
    Unless I missed it,I see the EURO cost,but what is that in U.S. dollars?. Thanks
    Germany, Werdau
    1,014
    @ randucci
    All disks have the same outer diameter. Just the 2 pictures are a bit smaller.
    The material? I don't know the exact type of steel. It is a std. brake disk steel, not stainless or cast iron.
    Yes, you can get only the disk without a adapter.
    @frog13
    The the base for the USD price is the EURO price.
    Here are the prices, based on the current exchange rate (1.00 EUR = 1.2957 USD):
    124.27 USD - 95.91 EUR for the std. disk
    128.29 USD - 99.01 EUR for the wave disk
    128.29 USD - 99.01 EUR for the teeth disk
    76.33 USD - 58.91 EUR for the adapter
  1. Front Brake Issues -disk
    By bikerjosh in forum Technical Help
    Last Post: 08-31-2015, 09:02 PM
  2. Front disk brake possibility
    By flyhunter3825 in forum Performance and Customization
    Last Post: 06-19-2013, 03:23 PM
  3. Front disk brake cover
    By abuck40 in forum Performance and Customization
    Last Post: 03-18-2013, 09:52 PM
  4. front disk brake cover
    By mdesheles in forum Performance and Customization
    Last Post: 03-18-2013, 06:58 PM
  5. Rear Disk Break? Feel Like It....
    By ronnydog in forum Performance and Customization
    Last Post: 08-12-2010, 03:00 PM
bike disk
converting ttr 230 to disk brakes
drum to disc brake adapter
how to convert drum brakes on a ttr 230 into disc
rear disc conversion for 2015 ttr 230
rear disk brake conversion for yamaha 225xt
rear disk brake kit for yamaha xt 225
ttr 230 rear disc brake
ttr 230 rear disc brake conversion
up grading tw 200 brakes
werdau htesf grryeqzd
yamaha ttr230 rear disc brake
