ttr225 donor
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Like Tree29Likes
Thread: ttr225 donor
    Senior Member spewingjason's Avatar
    Oct 2017
    111
    ttr225 donor
    I bought a 2002 ttr 225 today for parts, I want to big bore one of my tw's. Is the general consensus to use a modified tw output shaft in the the ttr cases with ttr trans, tw stator and flywheel, left case cover, tw head, ttr jug, and stock tw carb, rejetted?
    Pleasanton, CA
    5,688
    That essentially what I did, except I used the TTR head. There is one bearing in the TTR crankcase that will need to be replaced with the one used in the TW (a larger ID is needed for the TW output shaft). I didn't even rejet my TW carb since it runs great as is.
    Senior Member vanillagorilla1's Avatar
    Nov 2013
    yakima wa.
    792
    Thats how mine is built as well. I would highly recommend the wiseco high compression piston while youre at it. and take them JIS screws and trash them!
    jtomelliott49 likes this.
    93 tw. running like clockwork
    225 6 speed complete!
    82 honda gl500 silver wing. sold to a new home 11-24-17
    03 ducati monster 800sie. full rebuild and a danger to the public Hidden Content for sale
    Pleasanton, CA
    5,688
    Quote Originally Posted by vanillagorilla1 View Post
    I second this recommendation for a Wiseco high compression piston!
    Oct 2017
    111
    I'll be hitting you guys up for some knowledge soon. I tore down the TTR last night, getting ready to ebay the rest of the parts bike to fund the TW projects. I might snag a tw output shaft on here or ebay for a donor so I can stick my old motor on the shelf for a spare or whatever. Planning of high compression piston, but what about webcam cams for these? Worth it? Not looking to get crazy power, but a little boost whilst keeping it reliable would be cool.
    Nov 2011
    norcal nutjob
    3,305
    that's how mine is put together too, you'll be happy.
    Senior Member Lyterx's Avatar
    Jun 2014
    Etters, Pa
    471
    I ordered a stainless allen head bolt kit on ebay
    https://www.ebay.com/itm/YAMAHA-TW20...5Q9zeP&vxp=mtr
    1991 TW200
    Nov 2013
    yakima wa.
    792
    I’m going to do a web cam as well. Still undecided of what grind to use. Either the 389 or 389a. I hesitate to do the 389a and give up some low end torque. I’m also undecided on the spring kit to use. Probably the beehives but I’m not sure if the dual spring kit is more durable. It’s not a race bike and I stack on the miles so it’s gotta hold up in addition to making more power.
    Junior Member Rpmfly1's Avatar
    Jan 2018
    Des Moines, Iowa
    25
    On my ttr225 build I went with the 389a but I am stroking, boring to 74mm's and have a port job with larger carb and custom 1.5in ID exhaust which actually tames the cam due to increased volumn and free flow intake and exhaust. The 389a on a stock tw would be pretty radical and have a high rpm power band. I am using their most expensive spring kit since the cost difference in low. If you degree the cam where it actually is advanced or opening before the straight up cam alignment you start the power earlier or lower in the rpm range and this will bring the cam power into a lower rpm and widen the power band. I am running 13.0 to 1 compression Wiseco piston which will also increase torque. I make my own octane booster from toluene and xylene with other products. With the small capacity of motorcycle fuel tanks, you don't use a lot of octane booster so it is easy to carry extra on the bike or with my travel tanks already mixed.
    Nov 2013
    yakima wa.
    792
    holy crap 13:1!!! Im very curious how all of this work turns out for you. Im kinda disappointed I couldnt put together that engines only kit in a timely manner. I would have been a little more patient, but with the baby coming soon I wanted to be making forward progress. you out to do your own build thread as many are curious.
    Quote Originally Posted by Rpmfly1 View Post
  1. Replies: 5
    Last Post: 11-22-2017, 04:41 PM
  2. How to swap forks from a donor bike
    By LuvNot in forum Technical Help
    Last Post: 05-21-2017, 08:09 PM
  3. 04 ttr225
    By DKV in forum Performance and Customization
    Last Post: 04-26-2016, 06:53 PM
  4. Need a TDub Donor Bike To Build a Brat Bike
    By BkCntryCrwlr in forum TW200 Classifieds
    Last Post: 01-19-2015, 07:09 PM
  5. Picked up a donor Xt 350
    By Bucknutz in forum Performance and Customization
    Last Post: 10-22-2013, 06:38 AM
