Tachometer
Results 1 to 3 of 3
Thread: Tachometer
    Senior Member RTG's Avatar
    New Jersey
    447
    Hey does anyone know if it's possible to fit a Tachometer from a Yamaha older XT to a TW?
    Here are some questions:
    -Where does the XT tech connect to?
    -Can the same be done on the TW?
    I personally think it would just "look cool" to have a tach that has the same shape and look as the stock speedometer, as if the TW came from the factory with the tach.
    I'm sure someone has looked this already? I know the efforts would be more for the cosmetic reasons rather than pure function, as it's prob a whole lot easier just to install a nice new Vapor.......
    images by Richard Todd Giordanella, on Flickr
    "I've often said there's nothing better for the inside of a man than the outside of a motorcycle"
    Nov 2011
    norcal nutjob
    3,304
    i wondered the same thing, i'll be following along your thread.
    New Jersey
    447
    Ok looks like it's gonna be really hard to make that happen.
    The XT case has spot for a screw like connection to the Tach cable....
    I can't seem to figure where this connects to, is it the starter gearing or oil pump gearing?
    Bummer, I would love to have this tach, just because of it's looks, but seems like the amount of work to make this happen just wouldn't be worth it.
    Any idea's anyone?
    yamaha-xt350b-1991-tachometer_bigyau1152c-8_a2cf by Richard Todd Giordanella, on Flickr
  1. tachometer?
    By sakogu in forum Technical Help
    Last Post: 11-21-2012, 07:02 PM
  2. Tachometer?
    By Woodi23 in forum General Discussion
    Last Post: 09-18-2012, 04:48 AM
  3. Battery discharge = dead tachometer
    Last Post: 06-11-2012, 06:43 AM
  4. Trailtech tachometer install....info needed.
    Last Post: 03-17-2012, 05:27 PM
  5. What years had a tachometer?
    By motorhead in forum General Discussion
    Last Post: 05-28-2011, 11:01 PM
xt225 tach
