Curiosity regarding 250cc / 6 speed conversions - Page 3
Results 21 to 30 of 35
Like Tree31Likes
Thread: Curiosity regarding 250cc / 6 speed conversions
  1. #21
    Senior Member lbxr's Avatar
    Jan 2015
    Gold Beach Oregon
    337
    Quote Originally Posted by vanillagorilla1 View Post
    that makes sense. Ive had it approach the 400 mark a few times on WOT steep hills in first. I have yet to find a hill long enough at low speed to be an issue. Ive had a couple times where it would ping when lugging when It was hot but it subsided quickly. Ive never had to shut it down from heat. I always run premium fuel as well. Im hoping dropping the CR to 9.5:1 will help curb the heat a little and keep it from pinging. I am building the 250 as a complete and if it proves to be less reliable the 225 will go back in. I realize im pushing the limit further, but after a few conversations with frank and his kit thats 11.5:1 that he gets almost 30hp out of I think im well in the safe limit. he swears he runs just premium pump gas. I remember talking with you in moab a couple years ago and comparing notes. seems like out engines were close twins.....
    I remember that as well, I should have turned around and joined you guys....I think a 9.5 to 1 CR would be a better choice, especially when lugging the motor when it is hot.
    Willys714 likes this.
  2. #22
    Senior Member Spawner's Avatar
    Sep 2016
    Western Massachusetts
    118
    what the hell did I get a friday afternoon case or what!?
    You use the 200 fly wheel and the 200 stator and pickups stay with the tw left case. you will have no ttr electrics at all.
    that makes a lot more sense. thank you
  3. #23
    Nov 2011
    norcal nutjob
    3,276
    My 2000 TTR225 engine case was already machined to accept the kickstarter shaft assembly .
    mine too. it has the place and what looked like a plug that even says "kickstarter" but it needed to be machined, not just popped out.
  5. #24
    Senior Member ben2go's Avatar
    Jan 2016
    Upstate,SC USA
    206
    I'm glad I read this. I thought I read somewhere that the TW250 was a TTR225 bottom end with an ATV 250 cylinder and piston with head, and the TW200/225 output shaft machined to fit the TTR transmission and case with the TW200/225 side cover.
  6. #25
    Sep 2016
    118
    Question of the day, as I continue to amass parts... Will a cylinder head from a yfb250 work for a 250 conversion? yamaha part number 4BD-11101-03-00. My research says yes, but I figured better to double check than be sorry at assembly time. Thank you. Bottom end will be an 03 TTR 225, with a moto4 225 cylinder.
  7. #26
    Jun 2015
    Nova Scotia
    1,249
    If a 250cc would over heat at low speed high RPMs, would an oil cooler compensate adequately?
    I'd love to hear more on this. I've learned enough about these engines now that it's starting to make sense.
  8. #27
    Jan 2016
    Upstate,SC USA
    206
    Quote Originally Posted by Trail Woman View Post
    If you're not moving fast, there's no airflow over the oil cooler to cool it. Having the extra capacity will always help.
  9. #28
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    For real hot runs I put a little muffin fan on the cooler. For the winter I put a piece of canvas over the cooler that has elastic sewn in.
    Husqvarna TE300i Fuel Injected 2-Stroke 2019
    Yamaha XT225 - 1999 Serow
    Yamaha TW200Z - 2010
    Yamaha BW200 Electric Start! - 1986
    Yamaha TTR225R - 2003
    Husqvarna 701 Enduro - 2017
    Kawasaki Prairie 650 - 2002
  10. #29
    Junior Member Grundieg's Avatar
    Oct 2017
    4
    I have on my TW (125 originally) an 250cc engine. But it is XT250 engine...
  11. #30
    Pleasanton, CA
    5,554
    Quote Originally Posted by Grundieg View Post
    Interesting. . . . . . Is this an actual XT250 engine or an XT225 engine modified to be 250cc's?
  1. Part out after my 250cc conversion
    By TheLuigus in forum TW200 Classifieds
    Last Post: 10-26-2017, 08:23 PM
  2. High speed lag, not getting to top speed
    By jgaff in forum Technical Help
    Last Post: 05-11-2016, 10:03 PM
  3. New Honda Adventure 250CC bike.
    By ZDR1 in forum Other Bikes
    Last Post: 05-05-2015, 11:25 PM
  4. 250cc TW
    By Werloc in forum Performance and Customization
    Last Post: 05-06-2014, 07:44 PM
  5. Austria To India On a 250cc Bike
    By TW2007 in forum Off-Topic
    Last Post: 10-04-2010, 08:05 AM
tw200 hp gain
