Rubber Windscreen - and Rubber on Cyclerack
Results 1 to 10 of 19
    Member APV1's Avatar
    Oct 2012
    Somonauk, IL
    39
    Here's my TW200. I added Protaper ATV Hi Bars, Large foot pegs, Coleman Tank Saddle Bags, Coleman ATV Seat Pad, Cycleracks Rear Rack. I then made out of some sheet rubber a windscreen reinforced behind with thicker rubber frame. I also covered some of the Cyclrack with 5/8" rubber air hose that I slit and slipped on.
    RUBBER WIND SCREEN: It's an ok mod right now because the rubber bends when I was riding into a 10 MPH wind at 60 mph. I'll have to reinforce it with more of the thicker rubber or just add some bent wire hanger.
    I thought of trying this because someone mentioned about a plastic windscreen seeming like a guillotine when climbing steep off road hills. So I thought, why not rubber. That shouldnt hurt too bad hitting my throat
    The rubber sheets can be purchased from a number of suppliers like http://www.zorotools.com . You can use 1/8" thick for the screen (about $7 for a 12"x12" sheet) and 1/4"thick for backing ($8 for 2"x36") reinforced with bent hanger wire. I just use contact cement on both surfaces (follow package directions).
    The screen attaches to the post that the headlight cover attaches to. I punched a hole in the windscreen rubber a slid it on the post first, then the stock rubber grommet on next. The headlight plastic still slips in the grommet, only a little tighter.
    I then used two pieces of industrial strength velcro ( with adhesive backing - get it at any Menard's or the like) to stick the windscreen to the plastic headlight cover.
    If you order some rubber sheets get more than you need because having scrap rubber sheets have come in handy for other misc applications. I had the rubber already from some scrap pile I salvaged from years ago.
    Senior Member Retrofit's Avatar
    Mar 2011
    Simi Valley So Calif.
    395
    looks great! i might have rounded off the corners at the top just a tad to match some of the other corners, but it's a great idea and a creative solution.
    Sep 2012
    Northwestern Oregon
    1,092
    Nice,
    I like the way that the air hose makes the Cyclerack frame look thicker. That makes it look better than stock (in my opinion).
    Why did you add the hose?
    Senior Member mrbracket's Avatar
    Jul 2012
    Springtucky, Orygun
    631
    That is one clean Tdub!! Very Nice!
    You've got a friend in the Bracket Business! Hidden Content
    Get your TW200 Parts at ProCycle! Hidden Content
    Aug 2011
    Cayce, SC
    3,109
    I have to agree with retro. Clean up those sharp corners, other than that looks great. Not really sure why you wrapped the rack but i'm sure you have your reasons.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Member mpilla's Avatar
    Oct 2012
    Washington State
    35
    Slick and functional!
    Senior Member kennethshaw's Avatar
    Jan 2011
    170
    Cool mods. If you don't mind, can you tell us where you picked up the materials?
    Jan 2011
    170
    Maybe even a how-to for the windscreen? Thanks.
    Frosty Hollow
    12,974
    Once in a while I use some rear saddle bags with a metal brace/bracket over the cycle rack and under the saddle bags. The metal brace rattled on the cycle rack so I added cut hose sections similar to yourself. Sure helped muffle the rattle. Oh, and your color hose is better than the one I used (green).
    Oct 2012
    Somonauk, IL
    39
    Quote Originally Posted by Retrofit View Post
    Thanks. Yeah, it was a pretty rough cut. I'll clean it up some. I was going to cut the top in blocks to represent the knobby tires but decided not to.
  1. sidecover rubber grommets needed
    By Live2Ride in forum TW200 Classifieds
    Last Post: 03-02-2013, 04:41 AM
  2. Rubber Foot Pegs
    By lyfestyl in forum General Discussion
    Last Post: 08-15-2012, 09:23 AM
  3. Need: Rear fender rubber pad thingy
    By vn_grnt in forum TW200 Classifieds
    Last Post: 04-06-2012, 04:19 PM
  4. Butyl vs. Natural Rubber tubes
    By drake523 in forum Technical Help
    Last Post: 03-09-2012, 05:51 PM
  5. Unknown Rubber Part
    By ravenwoods in forum Technical Help
    Last Post: 06-22-2011, 08:26 AM
