Tubing or solid for spoke material on this project.
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Like Tree51Likes
Thread: Tubing or solid for spoke material on this project.
    Senior Member DougDotyTW200's Avatar
    Jan 2018
    Southern In.
    457
    Welded Spoke 6.5" wheel conversion for ATV tire
    I am going to attempt to weld spokes in between the hub and rim while in a jig. Curious if you guys and gals think that tubing or solid would be tougher in use. thinking (8) per side and 1/4" to 3/8" size range. Just cutting the spokes away and using the hub for a conventional trailer wheel hub is my backup plan whick would only waste the $35 wheel. I just think I would like the spoke look better if I can make this successful.
    EDIT: To include video link once done. Just came back from 15 mile test ride. Other than taking a small amount of power to pull the big tire at 10 psi, it rides very close to the same as before. The little bit of free spin wiggle I am seeing in the video is not detectable at any speed up to 55 thus far. Smooth and neat feel.
    Ken and PlacerLode like this.
    2016, stock'ish and a 2003 Starting on a 225 or bigger 6 speed build as a spare for now and install later when done and ready on this bike.
    Jan 2018
    Southern In.
    457
    Peterb, TW-Brian and Ken like this.
    Lower Rio Grande, New Mexico
    1,702
    There is a reason why every spoke wheel I own is equipted with adjustable spokes to true the wheel after every major shock experience. The only rigid spoke wheels I recall were covered wagons which had wheels that exploded on demand.
    Ken likes this.
    Central New Mexico
    Jan 2018
    Southern In.
    457
    Makes sense but I have never found a need to adjust a spoke in my life and bigger spokes welded in might not get knocked around as much ?? , Just trying something and wanting an opinion, I already acknowledged it might not work out so I see the potential flaws and failure modes, no help needed there !! I am willing to risk the $40...
    Peterb and Ken like this.
    Pleasanton, CA
    5,634
    Hey Doug,
    My first reaction when I first read about your idea was that you must have fallen and hit your head !
    Now, I am kind of digging it ! There is no reason at all why this won't work well, assuming that it is accurately jigged up and you are able to get good welds. My vote would be to use five tubular spokes per side, with my reasoning being tubes would be more rigid than solid bars and ten spokes should be plenty while still providing interesting aesthetics.
    What trailer wheel size are you using?
    I say go for it (and put me on the waiting list for prototype #002).
    Brian
    Ken likes this.
    Senior Member imlost's Avatar
    Sep 2017
    Portland, Oregon / East Cape, Baja Sur
    214
    Holy shinko that's a big tire.
    TWy to make a TWip to the TWails to make some TWacks.
    Jan 2018
    Southern In.
    457
    It is 14x6, a bit concerned about swelling the tire out that much so gonna mount this freebie tire of the 26x8x14 size to get good measurements first. Shoulda done that first but this tire just fell in my lap by accident today.
    I think I need an even # of spokes on each side to create opposing forces for acceleration and braking torque loads if I install at angles like stock, I am afraid if i just do them like an old wagon wheel the rotational torque from being driven and braking, might try to over stress them. ???
    Ken likes this.
    Jan 2018
    Southern In.
    457
    Got 3 more hours in on this project today...Got all the dimensions worked out, will double check all the #'s again tomorrow and finish the fixture. I settled on 3/8" 1018 crs for the spokes due to availability.
    Pleasanton, CA
    5,634
    Rebar would give it a nice hillbilly look !
    Jan 2018
    Southern In.
    457
    Got my dimensions all cross checked and confirmed, fixture jig done, need to remove a bit more paint before fitting and welding in spokes. P.S. I am experimenting with picture posting options so two pics of same thing here. let me know if you cannot see the one on the bottom !!
    Mel likes this.
  1. Revolutionary Solid state battery .
    By Tweaker in forum Off-Topic
    Last Post: 11-04-2017, 11:12 AM
  2. Tubing bender recommendations
    By Tirebiter in forum Performance and Customization
    Last Post: 03-23-2014, 07:19 PM
  3. Cycle rack tubing size?
    By wbpolk in forum Performance and Customization
    Last Post: 11-20-2013, 07:01 PM
  4. solid state flasher for leds
    By mkriley in forum Technical Help
    Last Post: 08-26-2013, 06:34 PM
  5. carb tubing
    By muzzy in forum Technical Help
    Last Post: 03-14-2012, 11:08 AM
news
reasons why tubing is better to use than solid material
