vstar shock for lowering
Results 1 to 6 of 6
Like Tree7Likes
  • 2 Post By Peterb
  • 3 Post By DougDotyTW200
  • 2 Post By grewen
Thread: vstar shock for lowering
    Member mrx916123's Avatar
    May 2011
    93
    will a shock from a vstar 1300 2014 work for lowering the tw?
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,453
    I don't know about the V-star shock but this is how I did it and it works great. my wife is 5'1" and can flat foot. Drill the swingarm and drop the fork tubes.
    Attachment 174770Attachment 174778Attachment 174786
    DougDotyTW200 and Sthrnromr like this.
    Senior Member DougDotyTW200's Avatar
    Jan 2018
    Southern In.
    457
    Quote Originally Posted by mrx916123 View Post
    Just done one today. Here is a picture my strategy, setting it up for a 5' 1" wife and or a same height buddy that rides this bike when we go out country roading. I am preparing to do several in and out TW200 services, this is one of those. In this case it is stretched 2" lowered 2-2.5" and has a 6.5" wheel with welded spokes and a 26x9-14 atv tubless tire conversion that I am still testing. I just laid out the new height on the shock stand, drill thru. and then have to mill about .100" from between the top area to give the round part of the shock body clearance to slide down inside where it used to reside. I mill away some of the area in front of the stand as well. plenty thick in this area to accommodate this mod.
    Dryden-Tdub, xupa and Peterb like this.
    2016, stock'ish and a 2003 Starting on a 225 or bigger 6 speed build as a spare for now and install later when done and ready on this bike.
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    Interesting weld d spoke setup. Nice job!
    Husqvarna TE300i Fuel Injected 2-Stroke 2019
    Yamaha XT225 - 1999 Serow
    Yamaha TW200Z - 2010
    Yamaha BW200 Electric Start! - 1986
    Yamaha TTR225R - 2003
    Husqvarna 701 Enduro - 2017
    Kawasaki Prairie 650 - 2002
    Junior Member gifty74's Avatar
    Apr 2019
    6
    So what is easier if you want to be able to change the ride height back and forth from stock to lowered? Drilling the lower mount hole lower or getting a Vstar shock?
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,324
    i would think it would be a lot less work to change 1 bolt, than to change a shock. you can do maintenance on the swingarm bushings when you do the drilling and after that it would be easy to go up and down
    Peterb and goldenhtr like this.
    Greg
    2018 honda cb500x
    2018 honda crf250l
    2018 honda grom
  1. Lowering with a V Star shock
    By antoine.drouin in forum Technical Help
    Last Post: 06-06-2016, 01:19 PM
  2. Vstar shock mod tire rubbing
    By Pint in forum Performance and Customization
    Last Post: 09-13-2015, 01:43 PM
  3. vstar shock . what is the correct way?
    Last Post: 09-10-2015, 04:01 PM
  4. TW Lowering Components XVS1100 Shock
    By mpilla in forum Performance and Customization
    Last Post: 11-06-2012, 12:05 AM
  5. lowering, vstar shock needed or alternitive
    By rastaman in forum Performance and Customization
    Last Post: 08-06-2011, 02:51 AM
1999vstarshock
