Painting Plastics
Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By Backtrack
  • 1 Post By olderthendirt
  • 1 Post By Fred
Thread: Painting Plastics
    Senior Member olderthendirt's Avatar
    May 2017
    wisconsin
    106
    Painting Plastics
    Has anyone painted the plastics (front/rear fenders, side panels, cowl) of their TW? If so, What did you use as far as primer and top coat. I would think top coat would be similar to painting a urethane car bumper by using flex additive in the base and clear coats.
    Any suggestions? Not looking to rattle can it.
    Thanks!
    Riding a TW is like riding a piece of freedom Hidden Content
    I don't want to go where the road takes me. I want to go where it does not.
    Junior Member Backtrack's Avatar
    Nov 2017
    25
    If you see my current post...Added Moose tank decal to my forest inspired bike "Tulane"....all painting was done with Rustolium rattle cans and came out great.
    Fred likes this.
    18,424
    Like Tulane and two of my bikes many of the TWs repainted here were done with simple spray paint cans. However there have been several discussions on more elaborate professional grade techniques which could be researched via "Similar Threads" or the "Search" feature on this Forum.
    Frosty Hollow
    12,909
    I can't remember anyone getting their plastics painted other than some form of rattle can. Not that it hasn't been done I just don't remember. At the bottom left of this page there could be some similar threads which may have some information you request.
    If you end up rattle can painting, there is a ton of info on that but you probably already have seen that.
    Good luck.
    Jun 2015
    Nova Scotia
    1,323
    I used spray paint made for plastic car rims. Some product lines have primers, some clear coats. Just light sand and degrease thoroughly before applying any paint. It's pretty tough and a little flexible. It takes grinding it on a rock or improperly removing your side plastics to damage it. If it does get damaged, just sand the area smooth and touch up. Touch ups are hard to spot if done right. Especially under a dusting from off road riding.
    May 2017
    wisconsin
    106
    Thank you everyone. I'm exploring a few options with my Dupont rep. Might just be less hassle to order the parts in the color needed. I'm not a rattle canner. I have never achieved the kind of finish I need from one. I'm a paint gun guy. Glass smooth and deep gloss shine is what I'm looking for. I'v been painting cars and drag boats for years. Plastics are just a bit new to me.
    Fred likes this.
    18,424
    Go with the molded in color desired if your bike goes off-road for damage to a paint job seems inevitable . The more stages of primer, color coat and clear coat the more layers one needs to remove in order to begin to restore a uniform luster and color consistency after a scratch.
    olderthendirt likes this.
    May 2017
    wisconsin
    106
    Thats also what I'm looking into Fred. I see Pro Cycle offers the plastics in black, which is the color I'm shooting for. By the time I add up materials and my labor time I'm thinking that might be the better option. And like you said...no need to touch up after I crash.
    Member billdapart's Avatar
    Apr 2018
    36
    I have had great success with SEM products on motorcycle plastics, and seats as well. SEM colorcote dye works quite well when used with SEM plastic prep. Comes in a TON of colors too. Might be worth a shot, if you can get it locally.
  1. Painting the National Anthem
    By Fred in forum Off-Topic
    Last Post: 02-27-2018, 07:01 PM
  2. Painting rims..?
    By dwil4 in forum Performance and Customization
    Last Post: 07-21-2017, 08:45 PM
  3. Painting Forks
    By tuhinuhi in forum General Discussion
    Last Post: 07-17-2013, 01:36 PM
  4. Painting
    By mike m in forum General Discussion
    Last Post: 02-25-2012, 08:56 PM
  5. Painting Advice?
    By bikerjosh in forum Performance and Customization
    Last Post: 12-16-2010, 10:14 AM
