Hard shell sealed camera box that fits the Yamaha rack perfectly
Results 1 to 3 of 3
Like Tree9Likes
  • 9 Post By DougDotyTW200
Thread: Hard shell sealed camera box that fits the Yamaha rack perfectly
    Senior Member DougDotyTW200's Avatar
    Jan 2018
    Southern In.
    457
    Title says it mostly but here is a couple of pictures. The molded in feet on the bottom of the box seem to fit the rack so well it kind of interlocks and only needs some form of hold down to secure. I just drilled .061 holes and used stainless safety wire to secure it. Just thought I would pass it along since it fit so well and was a 5 minute mod. Taking the pictures and sharing took 4x longer. I will seal with a dab of silicone. If the stainless wire proved inadequate then I will just slot the holes and use small hose clamps. It comes full of layers of foam. I just covered the botton with one of the 1/2" pieces to cover up the safety wire twists. Beefy zip tie would work great as well.
    Doug...
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    The picture posting here is crazy. Sometimes it rotates the picture and other times it does not but everytime it takes 10x the effort of typical pic hosting anywhere else. First picture is hosted if you can see it. Some can and some cannot is my understanding.
    2016, stock'ish and a 2003 Starting on a 225 or bigger 6 speed build as a spare for now and install later when done and ready on this bike.
    Member CatFlap's Avatar
    Aug 2017
    Sandy, OR
    55
    Nice.
    Another way to mount to racks similar to what you did with the safety wire is 120lb zip ties, they are kinda spendy though for zip ties. I have a small action packer mounted to my cyclerack with 6 of them. The math on that pretty much means the tote will obliterate before the ties let loose. Used some plates I found at the hardware store that have countersunk holes in them inside to reinforce the tote floor and I have the version of the rack with the turned up rear so two of the ties are back there with washers inside the tote to disperse the load a bit. Holds it tight to the back of the rack. Seat is a pain to remove though...... Planning to get a case like yours in the next few days, be better for trails being smaller just to carry some day supplies and I can strap my rubberized duffel to the top for camping and such. Tote is kinda big.
    Attachment 176898
    Attachment 176906
    2017 TW200 "Lagann"
    Cycle Racks Rack, Clarke XT350 4 gal tank, Rox 2" bar risers, 12v power port, Ram GPS mount, Coleman seat cover, Wolfman tank bag, HF "Pelican" style case attached to rack, LED headlight bulb, LED spot lights on the forks wired to the high beams, lots of mud caked on.
    Future mods: Ricochet skidplate, ATV tire for snow next winter, maybe a ManRacks front rack over the headlight.
    Senior Member Tuber's Avatar
    Sep 2012
    VT
    732
    you can use a threaded J hook, too. loop it around the rack, use fender washers inside the box
    2005 Tdub
  1. Replies: 14
    Last Post: 04-25-2016, 04:12 PM
  2. Rear Rack Yamaha OEM TW200 Rack
    By PlacerLode in forum TW200 Classifieds
    Last Post: 03-31-2016, 09:41 PM
  3. Rack Box $29
    By TW200! in forum General Discussion
    Last Post: 02-22-2016, 11:35 AM
  4. Replies: 10
    Last Post: 05-28-2015, 12:16 AM
  5. Newbie Question on Rack and Hard Case
    By wilco in forum General Discussion
    Last Post: 04-05-2011, 12:10 PM
