Big Bore engine builder?
Results 1 to 3 of 3
    Senior Member kenfyoozed's Avatar
    Sep 2012
    Alabama
    206
    Is there anyone who does the big bore engine build for TW's. I would love to have a bit more power, but my time is limited to build on myself. My idea would be to ship off my engine, or buy a used engine and have it rebuilt to the larger bog to gain more HP. Does anyone offer such a service? Or is this a pipe dream?
    Desert, SoCal
    7,369
    This outfit makes a big bore TOP END kit intended for the TTR and charges what I consider to be reasonable rates:
    http://www.xr100.com/ttr230.htm
    I think their rates are reasonable. But the main problem with the TW motor VS. the TTR/XT is the size of case mouth. So you're talking additional costs for splitting cases, enlarging the case mouths, etc. Be forwarned that the only way to get any real bang for the buck is by using the 225 crankshaft. Splitting cases, enlarging case mouths and and swapping crankshafts will generally put you into a whole nuther realm of costs.
    Just trying to give you some perspective of costs. This stuff is relatively cheap if done D.I.Y. but can get relly out of hand if someone else does the work.
    Ronnydog, Sebastian and others can probably give you a real estimate of costs to build an all-out, reliable TW motor.
    Ronny's D.I.Y., Sebastian builds motors for customers.
    Germany, Werdau
    1,014
    If you're a handyman, than you can make many things by your own.
    - changing the crankshaft
    - enlarge the crank case mouth for a bigger sleeve
    I can build for you a complete 250ccm engine with reliable parts, but the shipping will be the big problem.
    A other option is, that you can send me just some parts and I will make the important modifications.
  1. Big bore kit
    By mmthxtw225 in forum Performance and Customization
    Last Post: 10-20-2016, 12:04 PM
  2. Engine Builder
    By n2o2diver in forum TW200 Classifieds
    Last Post: 05-12-2013, 07:23 PM
  3. Why are there no big bore kits for the TW?
    By PalmStateCrawler in forum Performance and Customization
    Last Post: 10-27-2012, 01:35 PM
  4. big bore oil leak
    By Turtle Chaser in forum Performance and Customization
    Last Post: 08-26-2011, 02:44 PM
  5. Serious about big bore
    By Robbiecrean in forum General Discussion
    Last Post: 01-31-2011, 11:05 AM
