Suzuki vanvan 200 Fuel Injection TW200 conversion - Page 3
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 58
Like Tree145Likes
Thread: Suzuki vanvan 200 Fuel Injection TW200 conversion
  1. #21
    Feb 2018
    Western Pa.
    250
    I find it funny that anyone here in 2018 would question the superiority of Fuel Injection over the carb! It's about time the TW joined the 21st century! I have always had Chevy vans and when they went from the four barrel carb to F.I. it was a glorious thing
    Are there people here who prefer shoe breaks over discs?
    Peterb, Tinybear, Tweaker and 1 others like this.
  2. #22
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    Quote Originally Posted by sibyrnes View Post
    Why yes! There is a very popular member who does (not me).. lol But I know why and agree.
    elime and Smitty Blackstone like this.
    Husqvarna TE300i Fuel Injected 2-Stroke 2019
    Yamaha XT225 - 1999 Serow
    Yamaha TW200Z - 2010
    Yamaha BW200 Electric Start! - 1986
    Yamaha TTR225R - 2003
    Husqvarna 701 Enduro - 2017
    Kawasaki Prairie 650 - 2002
  3. #23
    Senior Member greenbomb's Avatar
    Apr 2014
    cherokee village Arkansas
    228
    Quote Originally Posted by JerseyJeeper View Post
    I store mine with ethanol gas all the time. All winter in fact, sometimes longer (no choice, can't get non-E). I always store it with Sea Foam in the tank.
    The trick to never ever having an issue (for me over many years) is to have a fuel filter in place, having fresh sea foam mixed in when starting the store-it period and most importantly:
    ALWAYS ALWAY ALWAYS drain the carb with the drain screw on the bottom that was in-fact put there for that purpose. Then run the engine till it dies from lack of fuel.
    I have never had a problem since I started doing this years ago, it only take 60 seconde of my time, the bike idles and purrs like a kitten every time.
    The tank looks shiny and new inside, never has slime and the filter is always clean, never been changed (it's a clear right angle filter with a screen).
    I always mix the sea foam in and let it run long enough to make sure it's mixed fully and through the carb (a five minute ride).
    Before I started this exact process I always had to battle it to get a good even idle and at times getting it started was a process to say the least.
    So, Add sea foam, mix it in thoroughly, run it through, use a good filter and drain your carb every time your done with the bike and you will never have a problem guaranteed.
    It's worked for me for 5 years flawlessly, even last year when i spent all my time on other bikes.
    Use the right screw driver on the drain screw and you'll be using the same drain screw for at least 5 years without issue.
    I USE Airplane Fuel from the local airport In all my small engines .
    Look at the bottom of this page under SIMILAR THREADS
    Norm in Arkansas
    2006 TW , Kick Starter , Shinko 241 front 4;00/18 ,Vesrah HD clutch springs. Carb jet Kit, Amsoil 10-40 , ALLSBALLS steering head bearings, Jimbo shield. Zeta drop -down bend handguards
    Ricochet skidplate from IMMIX RACING , BIKEMASTER Supersport mirrors XT350 fuel tank , member big foot pegs
    Honda XR 600 , KTM 300 , BMW 1100 gs , 327 Cushman Truckster , KTM 625 SXC . Ural with sidecar
  5. #24
    Mar 2011
    3,880
    Quote Originally Posted by greenbomb View Post
    I used too buy AV too but it has lead in it and my new bikes have oxygen sensors and cats and I can't put lead in them. It's also crazy pricey here and you have to buy 50! Gallons at a time or they won't service you. End of day what I'm doing draining the carb every time it's stored has been a perfect 100 percent solution. It's how boats are stored here in the winter on the jersey shore.
    I would say your solution was mine and it is a good one but when they went to the 50 gallon minimum and I got a newer bike it just wasn't worth the hassle for me. I was also afraid my son, wife or daughter famous gas thieves would put the leaded fuel in their car when I wasn't looking.
    Smitty Blackstone likes this.
  6. #25
    Member YamTW87's Avatar
    Mar 2017
    Greece
    91
    Well,is anybody going to do this or any other EFI conversion in the TW?
    2007 Suzuki V-Strom 650
  7. #26
    Jun 2015
    Nova Scotia
    1,246
    I'm actually considering the opposite direction and getting rid of my battery for a capacitor. I already have the cap and kickstarter....just waiting for the ambition to get into it. Probably this spring.
    Miaugi and PlacerLode like this.
  8. #27
    Mar 2017
    Greece
    91
    In order to save weight?
    Isn't it going to be more hassle having to charge it or jump start before each ride?
  9. #28
    Jun 2015
    Nova Scotia
    1,246
    Yes. It is a little give and take that I think I'll prefer. I'm richening up the fuel mix for easier starting and I'm adding kickstart weight down low that is easier to balance. The capacitor should be capable of electric start within 48 hours of running the engine. I've seen people use them in cars instead of batteries.
    Miaugi and YamTW87 like this.
  10. #29
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    7,802
    I am surprised no one has said this yet but I have been known to poke a bear now and again. Where the hell is QWERTY when we need him most?
    For those newcomers here and as a reminder to us older geezers, QWERTY claimed he had a highly modified TW #2. He claimed it had his own designed FI system and was producing near 20 HP and could reach top speeds near 90 MPH. Not one of us ever saw the bike in person or even in pictures and we have not seen QWERTY for at least a few years now. Most of us feel that his mother disconnected the WWW to her basement where he lived. Those are some bad memories from a while back here on the forum but QWERTY had it all figured out and all the rest of us were just ignorant fools in his opinion.
    1987 Yamaha BW350 Big Wheel
  11. #30
    Senior Member reddave's Avatar
    May 2018
    South Park, CO
    110
    Sounds like QWERTY wanted to "see if these bastards can do 90" and traveled through time back to 1955...
  1. Suzuki VanVan RV200 Question re Kick Start Option
    By PlacerLode in forum Other Bikes
    Last Post: 11-28-2018, 11:43 PM
  2. Replies: 84
    Last Post: 10-26-2016, 12:14 PM
  3. Suzuki Vanvan 125
    By Mame Shiba in forum Other Bikes
    Last Post: 05-20-2015, 05:22 PM
  4. TW200 Fuel Injection
    By Darth in forum Technical Help
    Last Post: 11-26-2014, 09:20 AM
  5. Fuel injection
    By garethllewelyn in forum Technical Help
    Last Post: 01-17-2014, 10:51 AM
2017 suzuki vanvan 200 vs yamaha tw200
fuel injected tw200
news
suzuki van van 200 vs yamaha tw200
suzuki van van gas tank upgrade forum
suzuki van van vs yamaha tw200
suzuki vanvan 200 performance
suzuki vanvan vs yamaha tw200
tw 200
tw200 vs vanvan 200
van van vs tw200
yamaha tw 200 vs suzuki van van
