30 mm ebay carb
Results 1 to 4 of 4
Thread: 30 mm ebay carb
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    Anybody try one of these cheap 30mm carburetors as a power upgrade
    http://www.ebay.com/itm/MIKUNI-Carbu...dd7d20&vxp=mtr
    It would flow much more than stock
    Experience , opinion ??
    Jun 2011
    AZ
    793
    Quote Originally Posted by Stromper View Post
    People use bigger carbs in Japan. FCR 33 ect.. Cheap one? Well if you can't get jets for it its no use.
    Senior Member mrbracket's Avatar
    Jul 2012
    Springtucky, Orygun
    631
    That carb pictured might be tough fit. The flange is part of the body of the carb, if it's different than the mounting to the TW head, could be very tricky. It is a Mikuni which means jets would be easy to find. It's a cheap experiment, but I would prepare yourself for blowing the $30, bonus if it did happen to fit!
    You've got a friend in the Bracket Business! Hidden Content
    Get your TW200 Parts at ProCycle! Hidden Content
    Germany, Werdau
    1,014
    It will be not easy to make a fitting adapter, to mount this carb on the TW cylinder head.
    Very important is the exact type of carb, because Mikuni does have many different jets and much more different needle jets.
    So, I recommend: No, search for a other carb.
    It is not so easy to choose the correct carb. The carb size depends from rpm range -> in which rpm range do you want the best performance.
    I've found some months ago a calculation to get the fitting carb size.
    Here are some results:
    -> 200ccm with 28mm carb
    from 4,840 to 6,125 rpm
    -> 200ccm with 30mm carb
    from 5,556 to 7,031 rpm
    -> 200ccm with 32mm carb
    from 6,321 to 8,000 rpm
    -> 200ccm with 33mm carb
    from 6,722 to 8,508 rpm
  1. 1987 @ eBay
    By azbusmo in forum General Discussion
    Last Post: 05-21-2013, 01:04 PM
  2. TW's for sale on eBay
    By PlacerLode in forum TW200 Classifieds
    Last Post: 11-17-2012, 09:55 AM
  3. 1987 CDI on Ebay
    By FortPayne in forum TW200 Classifieds
    Last Post: 06-13-2012, 04:43 PM
  4. Craigslist and eBay
    By emilliano in forum TW200 Classifieds
    Last Post: 02-27-2012, 01:55 PM
  5. Mikuni 30 MM ebay carb
    By Stromper in forum Performance and Customization
    Last Post: 11-08-2011, 01:16 PM
30 millimeter carburetor
fcr33 carb
tw200 fcr33
