Charging Tail
Results 1 to 10 of 14
Like Tree14Likes
Thread: Charging Tail
    Junior Member 100000 miles's Avatar
    Jul 2018
    FL OK
    28
    Charging Tail
    I couldn't find any positive battery leads to enable easy charging without taking the seat off, and with repeated carb issues and cold blooded nature, I often cranked the battery down trying to start the bike.
    My solution was to install a charging tail.
    I supposed I could have installed a female bullet connector for added ease but I hope you don't all reply saying I missed an obvious charging connector already on the bike somewhere!
    Did I?
    Badgerflorida likes this.
    Stanwood,Wa
    1,898
    I use this now.
    https://www.amazon.com/Battery-Tende...+charging+lead
    if you have more than 1 bike you can get just the battery leads for just over 5 bucks.
    https://www.amazon.com/dp/B000NCOKZQ...531836233&sr=3
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
    18,853
    An almost universal solution here is to simply wire in a flat 2-pole polarized 12v plug available at most automotive suppliers for a few dollars. Never seen the wire nut option, looks vulnerable. If you keep the exposed wire with wire nut I would suggest an inline fuse to protect against a catastrophic short circuit.plug.jpg
    Badgerflorida, Mel, Darth and 1 others like this.
    Jun 2016
    New Rochelle, New York
    1,775
    I just added a pig-tail to the '91 xr250L I purchased. One of the first things I did. This bike is "kick-only" so you definitely want to make sure the battery is charged all the time. It'll start without the battery too but pretty cold-blooded.
    I already have the Battery Tender (get a "plus" smart model, not the BT Jr.). The pig-tails can be bought separate. My local Yamaha dealer sells them for $6.00. Direct battery hook-up and can be used to power other things too.
    One of the tiniest AGM batteries for starting, turn signals and lighting I've ever seen.
    Like sipping a fine wine.
    Jan 2017
    Southern Nevada
    1,077
    If you lose the wire nut, the wire could ground.
    Is it fused?
    https://www.batteriesplus.com/produc...yABEgLFhfD_BwE
    Badgerflorida and Darth like this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Jun 2017
    Milwaukee, WI
    1,285
    They don’t come stock with a connector. If your carb starts leaking, be careful with things that create sparks in that area. Cheers
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Jul 2018
    FL OK
    28
    I've got a battery tender I can share so I'll pick up an extra pig tail. I think they include the fuse but I'll add one if not.
    Thank you all.
    Tweaker likes this.
    Senior Member mrlmd's Avatar
    1,156
    That lead you hooked up is incredibly dangerous as others have said. If that wire nut comes loose and you get a short, the heat generated in the wire would melt it, possibly start a fire, possibly explode the battery. so get rid of it fast. Get the plug Fred showed you, and you can also use it to plug in all kinds of temporary accessories, like a GPS, phone charger, etc. A fused one is best, but a straight polarized flat plug is OK too and the positive lead is protected. They are available all over the place and only cost a few dollars. Just hang it supported under the bike somewhere or sticking out where you can get to it.
    Jun 2016
    1,775
    Quote Originally Posted by 100000 miles View Post
    Thank you all.
    Yes, they come with a fuse. Get rid of that "MadMax" set-up as soon as you can.
    However... nice ingenuity anyways.
    Senior Member Rhodetrip's Avatar
    Aug 2010
    Out wandering around
    1,930
    I've done this to all my bikes now. Moved the charging port to the dash area, and I use it to charge, run my gps, volt meter and I have a usb port for the phone or camera batteries. Very handy.
    https://www.tw200forum.com/forum/per...ging-port.html
    "Me and Mrs Trip, we got a thing going on"... an on-going adventure...
    "When Piggies Fly" ...Me & Mrs Trip Cross the Pond
    "Take the Puppy to the Beach"...a dirt route across southern New England
    Latest Spotwalla: Hidden Content
  1. Over charging
    By bryns93tw200 in forum Technical Help
    Last Post: 11-16-2012, 02:13 AM
  2. Charging system output
    By TWMike in forum Performance and Customization
    Last Post: 05-12-2012, 08:23 AM
  3. Battery Charging System?
    By DBuck42 in forum Technical Help
    Last Post: 03-30-2012, 02:30 PM
  4. Charging a Car Battery
    By cptrout in forum Off-Topic
    Last Post: 01-08-2012, 10:01 AM
  5. 91 tw charging issue
    By mike438 in forum Technical Help
    Last Post: 03-13-2011, 08:25 PM
