Chinese Carburetor Success
Results 1 to 7 of 7
Like Tree12Likes
  • 5 Post By divetravis
  • 1 Post By Peterb
  • 3 Post By jbfla
  • 3 Post By mrlmd
Thread: Chinese Carburetor Success
    Junior Member divetravis's Avatar
    Feb 2018
    Belton, Tx
    5
    After purchasing my 2010 TW I was doing some initial maintenance and when I went to adjust the idle mixture screw I discovered it was turned all the way in and that is where it ran the best. From checking the spark plug it appeared to be running a bit rich but the bike performed great. Knowing something was not quite right I removed the carburetor and discovered that someone had been inside it at least once (the screws were badly mangled). I disassembled the entire carburetor, cleaned everything, blew it out with compressed air and set the float height. Upon reinstalling nothing changed, still ran rich and had to have the idle mixture screw turned all the way in. Repeated everything again and still no change.
    If anyone has any idea on what might be wrong I would love to fix the original carburetor.
    I decided to purchase one of the Chinese clone carbs off of Amazon for under $50. Installed the new carb and the bike fired right up. Set the idle and checked the idle mixture screw, I did not have to change it. Bike runs great but it is a little leaner than I prefer. The new carburetor is not an exact clone, the cable bracket is different but works fine. I did have to cut a slot in a nut and add it to the front cable, you could also simply swap your original bracket. I opened the carb and there are internal differences, the floats are different and the float level is different. Externally the threads on the idle adjustment screw are very slightly different and I could not use my original adjuster. The one that comes on the carb works but is not as convenient. I have been running this for a couple of months without any problems. I would have included a link to the one I bought but it is no longer listed on Amazon, the other listings are probably the same carburetor. Anyway I am happy but I would still prefer to have the original carb working correctly.
    2010 Yamaha TW200
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,468
    Perhaps the needle and seat are leaking or maybe just the o-ring on the seat?
    Badgerflorida likes this.
    Jun 2017
    Milwaukee, WI
    1,206
    Congrats!
    01 street 203/204
    96 hybrid Shinko 241/428
    89 restored SOLD
    Jun 2016
    New Rochelle, New York
    1,709
    I've never had a problem with what I assume is the original carb on my 2006. But it's nice to know there is actually a very close clone for use or even perhaps for spare parts.
    Under $50? That's great! I just paid $40.00 for a Kestar re-build kit for another bike and it wasn't an exotic Ducati or Bing BMW. It was for a 20 year old Honda.
    So that's a great price point you found there. And good for us we read it on the Forum.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,381
    Just a reminder if you are in the market for a TW clone carb: the carb shown is a clone of the Teikei CV carb used on 2001 and newer TWs.
    In the past, Mikuni clone carbs have been adapted to the TW. It can be done but requires some modifications.
    It is nice to see the Teikei clone readily available as a bolt-on replacement at a bargain price compared to OEM.
    BTW, that is the same carb I sent to "mrimd"
    jb
    admiral, JerseyJeeper and Darth like this.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,842
    Maybe your original has the jets to big swapped by the PO.
    Senior Member mrlmd's Avatar
    1,153
    And that carb works great on my 2000. My bike starts instantly and the throttle is very responsive.
    If I can figure out how to resize the pics I took of my installation/swap so they don't fill up the whole page, I will post it in another thread so you can see what's involved in switching the carb and how really easy it is.
    CJ7Pilot, Darth and jbfla like this.
  1. Vermont registration success for no title bike
    By dreynolds in forum General Discussion
    Last Post: 06-29-2019, 09:47 AM
  2. Success with sheered bolt on oil pan cover...
    By OSOK in forum Technical Help
    Last Post: 09-21-2013, 03:43 PM
  3. Cycleracks Success At Last!
    By DonBenito in forum General Discussion
    Last Post: 09-01-2012, 03:01 AM
  4. Carburetor help or different carburetor options
    By dz1 in forum Technical Help
    Last Post: 05-21-2011, 08:24 PM
  5. Valve adjustment success
    By bigdreama in forum Technical Help
    Last Post: 10-08-2010, 03:41 PM
