Aftermarket exhaust & carb options
Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 127
Like Tree10Likes
Thread: Aftermarket exhaust & carb options
    Aug 2011
    Cayce, SC
    3,109
    As many of you know, I have been fighting the idea that you can't power-wheelie a tw. So.... I picked up a 55t sprocket and was thinking maybe a new exhaust and re-jet with airbox mods might wake the little beasty up. I know that the exhaust wont do much but if it helps at all i'm willing to go ahead and pick one up. A dg is $160 on ebay.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Senior Member mrbracket's Avatar
    Jul 2012
    Springtucky, Orygun
    631
    I'm going to try a DG myself. I'm going to see how much I can squeeze out of the stock exhaust first with jetting. When I put the TM28 carb on for some testing it sure seemed to make the front end lighter. The flat slide carb just seemed to "spool up" quicker. I'm hoping that combining the TM28 and aftermarket exhaust will give mine so more pep! I'd say go for it!!
    You've got a friend in the Bracket Business! Hidden Content
    Get your TW200 Parts at ProCycle! Hidden Content
    Poway CA.
    2,099
    Best pipe I have heard so far is bikerjosh, he has the Big Gun and it sounded very dual sport, not to loud but throaty.
    Ronnydog
    Aug 2011
    Cayce, SC
    3,109
    Quote Originally Posted by mrbracket View Post
    I have played with jets and nothing gets me where I want it. Is the tm28 a push/pull carb? I will see what kind of prices I can get for the carb and exhaust from work tomorrow. I wish someone made a full exhaust for the tw. Airbox mod, flat slide carb and exhaust... we shall see.
    Aug 2011
    Cayce, SC
    3,109
    *I can pick up a TM28 for $110 from work. Are there any other carbs out there that I should look into or should I just go ahead and order this one?
    *My cost for a DG is $157 for an "o" or "r" series but the "o" won't be available til late January. I'm thinking that I would rather wait til I can get the "o" series. TW200 DG exhausts
    *The FMF would be $212.
    Aug 2011
    Cayce, SC
    3,109
    I'm going to take LB at his word and avoid buying an aftermarket exhaust if all it really does is make it louder. I am still going to order the flat-slide carb and see how that does. Can I use my push/pull cable or do I need a pull cable?
    Desert, SoCal
    7,369
    Might be interesting what MrBracket's dyno runs reveal about carbs, cams, pipes, etc.
    In the proper combination there may be some gains to be had. But I'm sticking to my story when it comes to otherwise stock TW's.
    Aug 2011
    Cayce, SC
    3,109
    Yeah i'm ready to see what an actual dyno will say about these. I may get an exhaust eventually but for now I am going to go with the carb. I don't want better top speed, just want to be able to get the wheel up while trail riding.
    Poway CA.
    2,099
    You my need to add some HP to easly get the wheel up.
    Ronnydog
    Jul 2012
    Springtucky, Orygun
    631
    I'm going to start on some carb testing soon, should be next week. I'm going to see on the dyno how much we can squeeze out of the stock carb first with jetting and exhaust. Also gonna pull off the side cover to see if the airbox is creating any kind of loss.
    Then, I'll switch to the TM28 to see what kind of gains that will net with stock exhaust and aftermarket exhaust.
    When I had the TM28 on there before, I just machined a little adapter to fit into the airbox side, the engine side fit into the stock rubber manifold. I used a whole different throttle tube and cable when I tested it the first time. The standard TM28 is not a push pull carb, just a single cable carb. We are going to build a custom cable we'll include in the whole carb kit that will fit in the stock TW200 throttle tube. You'll just run one cable instead of two. This of course assuming the TM28 is indeed a beter carb than stock. I'm betting it is, when I had it on mine it really felt like the flat slide made it take off quicker. The other thing about the TM28 is that the jets are much eaiser to get, and diffent needles are even availiable...
    My "butt dyno" says the TM28 is a good mod, we shall see what the real dyno has to say.......
  1. Aftermarket carb for TW200?
    By p808 in forum Performance and Customization
    Last Post: 01-08-2014, 09:07 AM
  2. For those of you with aftermarket exhaust
    By xdac in forum Technical Help
    Last Post: 03-02-2013, 07:12 PM
  3. options for a quiet exhaust
    By jwtwrider in forum Performance and Customization
    Last Post: 11-12-2011, 08:16 PM
  4. Is there really a need for this aftermarket part?
    By tripleted in forum Performance and Customization
    Last Post: 02-27-2011, 08:49 PM
  5. OEM or Aftermarket
    By thumper in forum General Discussion
    Last Post: 10-20-2010, 10:31 AM
aftermarket bigger carb for ttr 90
best aftermarket carburetor for tw200
mikuni vm 24 sc
tune carb two strokes tm28
tw200 aftermarketexhaust
tw200 exhaust
what all carbs fit on ytm 200
what jets are recommended for a ttr225 with aftermarket exhaust
will a mikuni vm24 fit on a yamaha ytm200
yamaha tw200 aftermarket carburetor
yamaha tw200 intake valve sell in singapore
ytm 200 carburetor
