Rear rack gear box
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree70Likes
Thread: Rear rack gear box
    Senior Member NVcowboy's Avatar
    Jul 2018
    Spring Creek, NV
    591
    Rear rack gear box
    So I just installed my Cycleracks rear rack. Thanks Don & Marc. Now I would like to put a SOLID gear box on it. My idea is that I want to mount my rotopax to the back of the box and the lid still open freely. I don't have the rear hoop on my rack so I have 14" to work with front to back, including the 3 1/2" rotopax. I would like to stay within the 18" side to side as well. Any ideas or suggestions would be most appreciated.
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,793
    Hey Cowboy...can't help you with your question, but just noticed your license plate .
    Thank you for your Service my friend...I appreciate you!
    "Faster, faster, faster, until the thrill of speed overcomes the fear of death."
    - Hunter S. Thompson
    Still, I rise!
    "Give a Damn"
    - C. M. Howe, Jr.
    Jul 2018
    Spring Creek, NV
    591
    My honor to serve. No worries everyone, found a tool box that fit perfectly, mounted it, tried it, hated it. On to the next bright idea.
    Jun 2014
    Bel Air Maryland
    4,169
    I added a 2x4 under mine and painted it black for extra support. I have heard way to many horror stores of broken welds. This should keep the rack from flexing.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,484
    I run a Pelican case and I like it. Waterproof and tough but a little on the heavy side.
    Ken likes this.
    Apr 2012
    Out West
    3,058
    I bought a TW that had this custom fitted Pelican box easy to take on and off and very durable and waterproof
    specially fitted for a Cyclerack
    "It's Like Warm Apple Pie"
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,395
    i tried the rotopax on top of the top box on top of the cyclerack. didn't work out for me. the fuel tank was too heavy for the hings on the top box and the top box and fuel tank were too heavy for the cycle rack. it worked a lot better with a bigger gas tank, no BS with fuel transfer and the extra fuel weight worked better up front25.JPG
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Senior Member Tuber's Avatar
    Sep 2012
    VT
    736
    I got a case from these guys...they are almost exact match to pelican but much less money. Various sizes available.
    Cases | Newark element14
    Ken likes this.
    2005 Tdub
    Senior Member CS1983's Avatar
    Aug 2011
    Tulsa, OK
    634
    Kinda like this?
    I like the idea of a 2x4 underneath to support it more. I should look into that.
    Hidden Content Hidden Content
    "I thought the slowest bike i have ever owned was going to kill me." - Hidden Content
    The John Birch Society is too Liberal.
    Member wersonst's Avatar
    May 2018
    Morris County, New Jersey
    37
    Quote Originally Posted by NVcowboy View Post
    Hey NVcowboy, thank you for your service! Too many people these days don't have a clue what you guys do for our freedoms and show no appreciation for the sacrifices our soldiers make!
    IMHO you bought the best rack in the market. I also run a Cyclerack without the rear end hump with a 18" x 18" x 12" box (Hardigg military surplus from Sportsmanguide) fixed installed on it. On a normal day, I carry about 40lbs but I pushed it to 65lbs and occasionally take it off-road. See my profile pic...
    After 3 years, the weld on the rear mount plate succumbed to fatigue. Not a welding or material issue, just that the rack flexes with that kind of weight and starts to swing around that weld point because the TW200, unlike most other bikes, does not have a real mount point any further back. Don and Marc are awesome guys and they replaced the rack... after 3 years of usage!!! These days, where do you find a company that stands by its product this way???!!!!
    So I was thinking along the lines of a wood piece or something similar as TopPredator is suggesting, and that probably works well for most cases. At the time I was (and quietly still am) planning a Singapore to Beijing trip with my TW. I was going to put significantly more on it than 65lbs... side cases with tools and spare parts, bag and tent on the top case.... so I knew that the sub-frame which is under the rack would not support that weight, especially with off-road bumps and an occasional catching air.
    Consequently, I put my engineering hat on and designed something I could print to solve the problem:
    The design is based on the direct line between the mount points changing length when the rack swings, so the force is actually push-pull between the mount points (horizontal) vs. push-pull is the direction of gravity (vertical). The subframe back there is not made to withstand a lot of vertical forces but it can handle plenty of force horizontally.
    I'm running with it for 2 years now and so far so good. With only 12kmi on this design I consider it a "tested prototype". I have not thought much about selling this directly, but if you're interested I'll send you one (for free ) for trying it out to let me know what you think how I can improve it and most importantly if you were able to break it!
    Cheers, Bert.
    1981 Vespa Piaggio PX80E
    1983 Zündapp KS80 Super
    2012 Yamaha TW200
  1. What's Under Ken Box, the Wanna-Be's Box
    By Fred in forum Off-Topic
    Last Post: 11-23-2014, 12:13 PM
  2. Protective gear/ Rear Rack For Sale
    By Tdubcruising in forum TW200 Classifieds
    Last Post: 10-24-2013, 09:41 PM
  3. Replies: 9
    Last Post: 07-22-2013, 11:25 AM
  4. Air Box, Battery Box, and Tool Kit
    By TW_Matt in forum TW200 Classifieds
    Last Post: 07-13-2011, 08:23 PM
news
