Longer Front Brake Lever
Results 1 to 8 of 8
    Poway CA.
    2,099
    I extended the stock lever 1 1/4, made a bracket for the cable 1 1/4 longer, filed the top of the existing cable stop for the bracket to bolt up flush, reassembled.
    [img]
    Ronnydog
    Poway CA.
    2,099
    This is the filed cable stop.
    Ronnydog
    Desert, SoCal
    7,369
    Very sexy.
    Stoppies now?
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    That looks great, I'll bet the front stopper is much improved.
    Senior Member Skyking's Avatar
    Nov 2011
    Frost, Texas
    572
    Nice work Dog. I'm worried that you may now have to much leverage on a filed down, cast aluminum cable stop. Your thoughts?
    Poway CA.
    2,099
    Quote Originally Posted by Kwizard View Post
    I thought there would be heavy leverage but there is not any leverage on that part it works as a guide only. The leverage is on the bottom lever and your hand lever if that makes sense. Felt braking much improved.
    I filed the half moon out only, but got some skuffs on the cable stop, it is still the same thickness.
    Ronnydog
    Pleasanton, CA
    5,681
    Quote Originally Posted by ronnydog View Post
    Hey Ronny,
    Did you actually extend the stock lever or were you able to find a longer one?
    Brian
    Poway CA.
    2,099
    Hey Ronny,
    Brian
    I did not find a longer one so I cut it in half and added 1 1/4" long piece of metal.
    Ronnydog
  1. Front brake cable/lever?
    Last Post: 11-09-2012, 02:37 PM
  2. Front brake cable/lever?
    Last Post: 11-09-2012, 01:48 PM
  3. Hard front brake lever
    Last Post: 02-25-2012, 10:32 AM
  4. Rear Brake Lever
    By FnMag in forum Technical Help
    Last Post: 12-20-2011, 12:43 PM
  5. front brake lever
    By RisingSun in forum Technical Help
    Last Post: 10-11-2011, 01:18 PM
