DIY Stone Guard
Results 1 to 10 of 10
Thread: DIY Stone Guard
    Senior Member mattmus4357's Avatar
    Oct 2012
    NW Arkansas
    250
    I've been looking for headlight stone guards, but decided I'd go ahead and make my own. It'll probably be this weekend before I get to finish it up since I don't have a welder. Anyways, here's my progress so far....
    Senior Member rm_hm's Avatar
    1,619
    May 2012
    Tucson, AZ
    976
    Those look like some pretty clean corners. How did you do the bending?
    2012 KLR650
    - Sold
    2013 Tiger Explorer XC
    2014 CB500X - RRP L3
    Oct 2012
    NW Arkansas
    250
    Quote Originally Posted by DonBenito View Post
    Made the jig out of scrap wood and sheetrock screws, then just heated the metal with my propane torch and bent it around the screws. Worked pretty well. It's my first time fabricating anything out of metal so we'll see how it turns out...
    May 2012
    Tucson, AZ
    976
    Quote Originally Posted by mattmus4357 View Post
    Wow! That's pretty impressive.
    I would've thought you'd need either a bender with the right die or some kind of black magic to pull those corners off.
    I've been on the fence about picking up a less expensive flux-core arc welder (Harbor Freight has some highly rated ones for around $120), one of the reasons being that it's great to be able to stick pieces of metal together, but without all of the other tools from the metal shop I've had my doubts about being able to make the right size and shape pieces of metal to weld together.
    I guess people bent and shaped metal without anything but heat, hand tools, and patience for a few thousand years though.
    Nice work, thanks for the inspiration!
    2012 KLR650
    - Sold
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    Looks good, I want to do something like that for mine, please post the finished project.
    Oct 2012
    NW Arkansas
    250
    @DonBenito
    I've been thinking of picking up the 90 amp mig welder from Harbor Freight. It's on sale for $109 right now, and I hear they're pretty decent units if you swap out the wire for quality wire.
    @r80rt
    Thanks. I'll definitely post my progress. (Unless it turns out bad, then I'm just busy and can't find time to finish... )
    Oct 2012
    NW Arkansas
    250
    Getting closer...
    Senior Member mrbracket's Avatar
    Jul 2012
    Springtucky, Orygun
    631
    Lookin good Mattmus! I want to build something similar that integrates some extra light mounts so I can add some LED headlights that will replace my high beam. I often ride early in the morning before daylight and the stock headlight leaves a lot to be desired..... Keep up the great work and thanks for sharing!
    You've got a friend in the Bracket Business! Hidden Content
    Get your TW200 Parts at ProCycle! Hidden Content
    Oct 2012
    NW Arkansas
    250
    Quote Originally Posted by mrbracket View Post
    Thank you, sir! It'll have to wait to be finished till this next weekend. The welder I was going to use ended up not working out, so I'm going to by a little wire feed unit.
    I'm going to add some 3" LED lights to the reflector brackets on the forks. Should ad a ton of light
  1. Headlight stone guard
    By evan in forum Performance and Customization
    Last Post: 04-17-2012, 07:15 PM
  2. headlight stone guard
    By Retrofit in forum Performance and Customization
    Last Post: 03-31-2012, 10:36 AM
  3. swim arm guard....
    By naveenlakdeep in forum General Discussion
    Last Post: 03-24-2011, 10:41 AM
  4. Headlight guard
    By TK200 in forum General Discussion
    Last Post: 12-18-2010, 08:17 PM
  5. Stone Mountain,Georgia
    By Xracer in forum Trails, Off-road, and Adventure Riding
    Last Post: 09-24-2010, 08:35 AM
diy headlight rock guards
diy headlight stone guard
diy hella stone gaurds
diy light stone guard
dyi stone guard lights
homemade stone guard
homemade stoneguard
off-road headlight stone guard
skid plate tw200 homemade
tw200 forum headlight guard
tw200 headlight guard
tw200 headlight stone guard
