Is there such a thing as a quiet aftermarket muffler?
Results 1 to 6 of 6
Like Tree3Likes
  • 3 Post By Leisure Time Larry
Thread: Is there such a thing as a quiet aftermarket muffler?
    Junior Member talon125's Avatar
    Jul 2018
    29
    I'm looking for an aftermarket muffler that's quieter than stock. Does such a thing exist?
    Jul 2012
    Wet-ern Washington
    1,410
    Not that I know of. You can search threads where hunters and such have worked to silence the exhaust... only to find that the engine itself is a noisy rattling machine, so there is no such thing as stealth mode on a TW.
    scotti158, Peterb and Dryden-Tdub like this.
    - Leisure Time Larry -
    Member Columbanus's Avatar
    Jul 2015
    67
    Some folks around here have had success with a 45 degree elbow (I think 1 inch ID but check) attached with the outlet facing down to reduce noise slightly. Get a copper one to look snazzy!
    Senior Member Ski Pro 3's Avatar
    May 2014
    El Dorado, California
    802
    Yup copper pipe 45 elbow and angle down. The sound is directed to the earth and the bike is a lot less noisy. Also, a stainless steel header pipe made a difference on mine as well. Skid plate with a closed cell foam pad between the motor and the plate quieted things too.
    The bear slayer!
    18,833
    Induction roar, misc mechanical and drive chain rattling can all be better appreciated with improved exhaust note muffling. One of my TWs has this second industrial muffler attached to the stock muffler. This something OP can readily accomplish since no quiter aftermarket pipes seem to be available.Wave.jpg
    I recently removed 1" copper 45 degree elbow from the other TW as it actually made the exhaust note louder for the operator, something not reported for those who use 3/4" copper 45 degree elbows. Odd.
    Senior Member mrlmd's Avatar
    1,156
    I'll send you the one I just took off my 2000, it's quieter than the new stock 2013 I just put on. Maybe because of all the rust you can hear rattling around inside, possibly muffling the noise a little.
  1. Update on using fiberglass wrap to quiet muffler
    By RockyTFS in forum Technical Help
    Last Post: 07-06-2018, 09:33 PM
  2. What is the most quiet muffler?
    By LuvNot in forum Performance and Customization
    Last Post: 04-07-2016, 08:07 PM
  3. Quiet muffler options?
    By Ricklesss in forum Technical Help
    Last Post: 02-27-2015, 07:08 AM
  4. I'm such an idiot !!
    By 00 tw125 nos in forum Technical Help
    Last Post: 01-25-2014, 02:02 PM
news
