Tw200 air filter
Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By YamTW87
  • 1 Post By Xracer
Thread: Tw200 air filter
    Junior Member Nath's Avatar
    Oct 2018
    1
    Tw200 air filter
    Which air filter do you use on your tw200 custom with a stock carb ? thank you !
    Junior Member Spoony's Avatar
    Aug 2018
    Washington
    Replaced the stock foam with K&N.
    Feb 2017
    Waretown NJ
    532
    Its my opinion that paper filters are not the best for dirt bikes. I Would think they are done once they get wet they wouldn't pass air once they wet. I also never used one on a bike so take my opinion for what that's worth
    87 TW
    Senior Member YamTW87's Avatar
    Mar 2017
    Greece
    123
    I wouldn't suggest the KN filter.Expensive,harder to properly clean,less filter area(so it seems at least). Use HifloFiltro HFA4202(OEM or even better quality),Yamaha 2JX-14451-00(OEM) or UniFilter NU-3219ST(a bit more free flowing).
    The best practice in my opinion is to replace it at manufacturers intervals with one of the foam filters.
    2scoops likes this.
    Senior Member Gulfrider's Avatar
    May 2014
    Florida Panhandle
    587
    Uni for me
    2005 TW200
    2007 Sportster 1200
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,694
    My personal experience with K&N filters is if they get wet they will let dirt pass through. I had to rebore the cylinder of my Suzuki and clean all the crud from the carb after the K&N failed. Now I run the stock or a good after market oiled foam filter.
    Peterb likes this.
  1. Fuel filter vs no fuel filter
    By naluboy in forum Technical Help
    Last Post: 01-03-2014, 12:48 PM
  2. New TW200 Air Filter now in the USA!!
    By mrbracket in forum Performance and Customization
    Last Post: 03-01-2013, 11:38 AM
  3. air filter part number
    Last Post: 06-18-2011, 12:59 PM
  4. K&N or that style air filter
    By ZXtasy in forum Technical Help
    Last Post: 01-20-2011, 02:46 PM
  5. stock air filter
    By triple3jrb in forum Performance and Customization
    Last Post: 09-28-2010, 07:25 PM
yamhama tw 200 after market carb and air filter
