The front tire...
Results 1 to 10 of 10
Like Tree12Likes
  • 1 Post By Idon'thaveoneyet...
  • 6 Post By Badgerflorida
  • 1 Post By Petro24
  • 1 Post By Maxpower
  • 1 Post By Gulfrider
  • 2 Post By Idon'thaveoneyet...
Thread: The front tire...
    Member Idon'thaveoneyet...'s Avatar
    Jul 2018
    Kenai Peninsula, AK
    77
    The front tire...
    I have been reading the pros and cons of the sweet tw200. I love all of the pros. The only cons that have me concerned are the small OEM fuel tank, the small OEM foot pegs, and the front tire. As a purely amateur rider, is there any reason to avoid this bike because of the tire? I don't really want to replace it right off the bat. If it was that big of a problem Yamaha would have fixed it by now, right?
    Also, is there an issue with the rear tire being wider than the front tire when it comes to making corners?
    Elvesus likes this.
    Jun 2017
    Milwaukee, WI
    1,285
    On pavement the stock tires are fine in my opinion, although there are many that are safer and perform better. There are many reports of the front tire washing out during off road riding. My opinion is that it’s like most other bikes - take your time learning it’s characteristics before you push anywhere near the limit of your comfort level. Cheers
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Junior Member Petro24's Avatar
    Sep 2018
    11
    The only reason to not buy a TW200 is if you plan on doing highway riding at 60 mph for long stretches. Other than that, the gas tank is sufficient unless you plan on getting lost in the wilderness. If you do such a ride, where you may get lost, strap on a gallon or purchase this... http://a.co/d/dxsUXyD Also, I just installed these low cost footpegs: http://a.co/d/bXj1AXz Many in the forum said they are good. I've owned many different bikes and ATV's and the TW is, by far, my favorite!!
    Quote Originally Posted by Idon'thaveoneyet... View Post
    Elvesus likes this.
    Senior Member bartruff's Avatar
    Oct 2018
    Wenatchee Wa.
    196
    I have had zero problems with those concerns and have ridden several of these bikes many thousands of miles and for more than 30 years....no doubt there are riders that have bigger feet than I do....who ride much faster than I do....and go farther than I do...that tank will take me more than 50 miles in a day and that is plenty of boondocking for me..
    Any bike is dangerous on high volume mixed traffic public roads with high operating speeds....but a bike that is holding up traffic is much more dangerous... so I would take Petro's advice …...
    Mar 2015
    Ynys Môn
    4,592
    The front tire is pants, the tread “cups” on the road, and introduces you to your dentist off road
    Bigger foot pegs are widely available, and personally I find that carrying an extra half gallon of gas will get you out of most situations – after 100 miles on the stock saddle, your butt will tell you all you need to know ……
    - Hidden Content
    Oct 2018
    Wenatchee Wa.
    196
    I haven't had any trouble with the front tire....if I am riding a significant distance on pavement I inflate it to 30-35 cold psi.....off road between 15 and 18....or even lower in a low traction area....with a bead lock of course..
    If a tire is cupping it is because it is bouncing....the rim or the tire could be out of round....the alignment could be bad....the balance or run out could be bad....the bearings could be bad....the shocks may not be able to control the road surface...or the tires maybe underinflated...is this a common problem ? I have never heard of it outside of this forum…
    Feb 2017
    Waretown NJ
    556
    I have no problem with the footpegs.
    The tank is too small for me.I bought a Clarke tank.
    If you like to rail berms or rip through whoops or ride with traffic at 65mph, there are better choices.
    bartruff likes this.
    87 TW
    Senior Member Gulfrider's Avatar
    May 2014
    Florida Panhandle
    587
    The pegs like others have mention are cheap. The Krators on amazon or ebay are around $20 and a nice upgrade. The clark tank is a very popular option too for fuel. The front tire, well its ok. Just if you are doing aggressive offroad it can be sketchy. But again a different front tire ain't that much. Don't think the fuel will be a issue unless you go on a long offroad adventure.
    2005 TW200
    2007 Sportster 1200
    Senior Member NVcowboy's Avatar
    Jul 2018
    Spring Creek, NV
    591
    I upgraded to the Krator pegs, love em. Only had 1 issue with the stock front tire but I'm sure any tire would have done the same on that super loose golf ball gravel I was on. Other than that, I'm staying with the Death Wing. I will probably get the larger Clarke tank as I plan long rides with a couple hundred miles or more between fuel stations, even with a rotopax on board. I find the bike as stable and easy to ride as I could hope for.
    If you have to shoot, shoot. Don't talk. - Tuco Juan Ramierez aka "The Rat"
    There's 2 kinds of people in this world, those with guns, and those who dig. You dig. - The Man with No Name
    2018 TW200 - LCpl. Rex T. Dubber
    2010 Savage S40 650
    Jul 2018
    Kenai Peninsula, AK
    77
    Thanks for all the info. I don't plan on riding in too extreme a situation, so it seems all the OEM stuff should suit me just fine!
    bartruff and Elvesus like this.
  1. TW204 front tire and rear stock tire
    By jgaff in forum Performance and Customization
    Last Post: 06-07-2015, 01:37 PM
  2. Big Tire BW200 Rear Front Tire
    By Beauew in forum Performance and Customization
    Last Post: 05-04-2015, 05:48 PM
  3. FS: CO - Shinko SR244 front tire and Bridgestone TW34 rear tire
    By Nicholast in forum TW200 Classifieds
    Last Post: 12-06-2014, 10:02 PM
  4. Best front tire for Wide Front Tire mod?
    By RiskEverything in forum Performance and Customization
    Last Post: 06-02-2014, 07:26 AM
  5. Replies: 10
    Last Post: 12-07-2013, 05:02 PM
tw200forum front tier
