Mods that don't require frame surgery.
Results 1 to 8 of 8
Like Tree4Likes
  • 3 Post By Stevelancaster24
  • 1 Post By Stevelancaster24
Thread: Mods that don't require frame surgery.
    Junior Member Stevelancaster24's Avatar
    Oct 2018
    Southport
    5
    The following are some photos of my tw with some changes that are bolt on ready, or fabricated to attach to a stock bike.
    -Front headlight fit where the old one did, no cutting, or fabrication. Just unplug old and plug in new.
    -Same with front flashers, though they did require washers. Wiring on the bike is unmolested, all connections were made using the similar Male female plugs that come with the bike.
    -Side plastics removed and fabricated new ones out of metal. A little bit different shape, but mounts exactly the same. Metal tabs on backside fit snug into rubber grommets, opposite side uses existing airbox screws.
    -Removed rear subframe that houses fender, flashers, and tail light. Fabricated a piece of flat bar to to install new blinkers to. Tail light mounted underneath seat for now.
    Fenders are on way, I will update with complete bike later.
    I know people like to customize their bikes, as do I. But like most people I want to be able to put it back together just like it came from the factory. These mods require zero frame surgery, and was fun to do. Thought I'd share, thanks!
    Dryden-Tdub, Xaman and Darth like this.
    Jun 2016
    New Rochelle, New York
    1,775
    I'm liking your round headlight mod. Im not sure I could get away with the amber lens around where I live but the round light, really looks good.
    The grill in front of it too.
    1995 BMW K75 (Elec Start)
    Senior Member Tjmay's Avatar
    Jan 2018
    Destin Florida
    234
    Quote Originally Posted by Stevelancaster24 View Post
    I like that look and I like that it installs with no modification.
    Could you source that for us?
    Honda CB150
    Triumph Cub
    Honda 250
    Triumph Bonneville
    Current Bike: TW200 Named Sloth
    She’s slow and can climb a tree!
    Oct 2018
    Southport
    5
    https://www.ebay.com/itm/6-3-Grill-A...AAAOSwsiZbRGsX
    I did have to notch out the rear opening of the headlight with tin snips. It fit, but wouldnt point down far enough. It's a simple 5 min job. Also. The headlight isnt as bright as the original.
    Oct 2018
    Southport
    5
    Added ammo box for storage.
    Xaman likes this.
    Feb 2018
    Western Pa.
    310
    Nice touch!
    Senior Member EatElk's Avatar
    Sep 2018
    Boise, Idaho
    298
    Great looking Bike! How did you mount the ammo can?
    Senior Member Mr.Paynter's Avatar
    May 2011
    Durban, South Africa
    330
    Looking great!
    Love those side panel replacements and thanks for the headlight link as well! Great find for an almost straight bolt on!
    Finally picked up a Tdub...
  1. Prayer for Gene's Cancer Surgery (Excalibur)
    By littletommy in forum Off-Topic
    Last Post: 03-18-2018, 10:09 AM
  2. When can I ride again? Surgery?
    By rivershot in forum Off-Topic
    Last Post: 11-23-2016, 03:10 AM
  3. Will this speedo require special wiring or will it be an easy conversion?
    By tree.bobby in forum Performance and Customization
    Last Post: 05-14-2016, 04:53 PM
  4. Replies: 26
    Last Post: 11-25-2014, 09:46 PM
  5. Replies: 6
    Last Post: 02-07-2012, 08:49 PM
