Before I fab my own...kickstand/side stand foot extender/expander?
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Like Tree50Likes
Thread: Before I fab my own...kickstand/side stand foot extender/expander?
    Oct 2018
    Rural, South Carolina
    670
    Before I fab my own, which I still may do, but would like to have options and ideas, has anyone here found any kickstand/sidestand expansion feet that fit directly on the TW200 stock stand foot? There are only ~million options on fleBay but would prefer not to trial and error endlessly. Any feedback or links to confirmed fits would be appreciated. Anything to help surface area of stand in soft conditions besides finding rocks and wood would be appreciated. Thanks all.
    Offroad:
    TW200 - The Goat
    KTM 300 - Orange Dragon
    ATVs
    Onroad:
    Triumphs
    Way too many past bikes and builds to list. I won't bore you. Questions? Just ask.
    Pleasanton, CA
    5,747
    I had my good friend Joemama weld a big old washer onto a sidestand for me.
    Nov 2011
    norcal nutjob
    3,329
    ditto on the kickstand, though mine isn't as pretty.
    mr mama does nice work.
    TW-Brian, Sthrnromr, Fred and 1 others like this.
    Pleasanton, CA
    5,747
    Quote Originally Posted by joeband View Post
    Neither are you !
    Joemama and Fred like this.
    Senior Member Tiny-Wheel-200's Avatar
    May 2013
    Wasilla, Alaska
    726
    drill a few holes in your bottom and screw or bolt on some .75 or 1.125 plywood. I did this and rode for years. I did one in steel on another bike but prefer the plywood
    Sent from my LGL63BL using Tapatalk
    Senior Member Ski Pro 3's Avatar
    May 2014
    El Dorado, California
    802
    No photo but I found the kick stand to be a bit short, bike leaned over too far, so I welded on a washer, then to that I mounted a hockey puck with three nut/bolts. Worked pretty good. Later I replaced the whole kick stand arm with one off a TTR250. That was better since the bike both stood up straighter and I didn't keep hanging up on the puck when I'd drag a leg. I did extend the spring as it was now a little short to reach the frame hole it goes in. I took a nail and bent it into a loop. That worked!
    The bear slayer!
    Senior Member Joemama's Avatar
    Apr 2012
    Lake County, Ca.
    1,249
    I didn't like how far my bike leaned over either. With my bum legs, I have to mount the bike by first stepping on the left peg. I almost tipped the bike over before I started from scratch and made a complete different stand. The bike now stands almost straight up.
    Oct 2018
    670
    Welp, it sounds like fabricating something is the only way to go. I’ll post some pics if I come up with something decent. Thanks.
    Smitty Blackstone likes this.
    Offroad:
    TW200 - The Goat
    ATVs
    Onroad:
    Triumphs
    Nov 2011
    norcal nutjob
    3,329
    Quote Originally Posted by tw-brian View Post
    neither are you :d!
    << unlike>>
    18,853
    Drilling and bolting on a foot allows some flexibility compared to welding. Bigger footprint sure helps in soft stuff. Current bolted plate has turned uo edges and has silicone pad on bottom for traction on rock. Last comercial model I saw got destroyed on a buddy’s bike on our last group easy ride so I recommend a minimal investment.
  1. Center Stand and Wheel Stand
    By Purple People Eater in forum TW200 Classifieds
    Last Post: 08-12-2016, 11:42 AM
  2. Polished my side stand today...
    By twlover in forum Other Bikes
    Last Post: 09-03-2014, 01:15 AM
  3. Extended swing arm ,chain & break rod extender
    By Old man in forum General Discussion
    Last Post: 03-04-2014, 06:19 PM
  4. Inexpensive range extender
    By Ready to Ride in forum General Discussion
    Last Post: 03-04-2014, 07:29 AM
  5. Right Side / Brake Side Passenger Foot Peg and Bracket
    By natehunts in forum TW200 Classifieds
    Last Post: 08-31-2013, 05:07 AM
