XT225 Sprockets on TW200?
Results 1 to 6 of 6
Like Tree5Likes
  • 1 Post By Leisure Time Larry
  • 1 Post By joeband
  • 3 Post By TW-Brian
Thread: XT225 Sprockets on TW200?
    Junior Member ChrisB's Avatar
    Dec 2018
    10
    So I’ve been wanting to change the countershaft sprocket on my TW200 from a 14 tooth to a 16. The only issue is that you can only buy a 16 for the XT. Do you guys think it would still be compatable? Also I realize a 44 rear sprocket would have the same effect, the countershaft sprockets are just far cheaper.
    Jul 2012
    Wet-ern Washington
    1,410
    I think that they are different. PBI sells a 16 for the TW200... https://shop.pbisprockets.com/product.sc?productId=329
    It is a much bigger pain to change the TW front though. You have to take off the left side engine cover. If your gasket is bad, scraping sucks, and then you'll need to replace it. It is better with two people when reinstalling, to prevent pinching/cutting the stator wires because that magnet can make it surprising. Much easier to change the rear if all you want is a ratio change.
    admiral likes this.
    - Leisure Time Larry -
    Nov 2011
    norcal nutjob
    3,329
    i don't know for a fact, but i'd guess they would as the shafts are nearly identical... minus the extra length. that's how the tw shaft can be swapped into the TTR/XT motor.
    Fred likes this.
    Pleasanton, CA
    5,747
    Hi Chris,
    Welcome to the forum!
    PlacerLode just recently confirmed that a 16 tooth front sprocket will work on a TW. See post # 11 on the following thread:
    https://www.tw200forum.com/forum/tec...-question.html
    It shouldn't matter who you buy it from, or if it is intended for the XT225, it should work fine for your TW.
    Brian
    Dec 2018
    10
    Quote Originally Posted by Leisure Time Larry View Post
    Thanks for the response Larry, that’s a good thing to keep in mind. May just spend the extra bucks on the rear one. Would I need to replace the chain as well if I lowered the sprocket to a 44?
    Dec 2018
    10
    Hi Chris,
    Brian
    Thanks man I appreciate it. And that’s awesome I figure if I can save $30 I should definitely look into it
  1. XT225 clutch in a TW200
    By GoNOW in forum Technical Help
    Last Post: 08-04-2016, 11:51 PM
  2. Will xt225 gas cap and petcock fit TW200?
    By scott in forum Technical Help
    Last Post: 09-21-2012, 10:25 PM
  3. XT225 clutch in a TW200
    Last Post: 11-24-2011, 01:24 AM
  4. 2009 TW200, 474miles, cycle rack, dual sprockets
    By muliefever in forum TW200 Classifieds
    Last Post: 06-10-2011, 03:47 PM
  5. TW200 or XT225
    By ckahleer in forum General Discussion
    Last Post: 02-20-2011, 09:14 AM
