Handlebar CAD Simulator/Need stock dimensions
Results 1 to 10 of 11
Like Tree14Likes
Thread: Handlebar CAD Simulator/Need stock dimensions
    Senior Member nihil's Avatar
    Jan 2018
    313
    I've been having a hard time deciding on which bars to replace my bent ones, so I wrote a parametric handlebar simulator in OpenSCAD so I could compare the various bars against stock. My bars are bent and still have all their accessories mounted, so taking measurements was probably less than accurate. Does anyone have a set of stock bars they can measure using the standard chart?
    The measurements I got by eyeballing were:
    A = 790
    B = 75
    C = 70
    D = 190
    E = 90
    F = 215
    So far I'm liking the ProTaper Trials Mid, as I think they'll go well with my existing risers without having to do too much in the way of lengthening cables/wiring (stock in grey/transparent, ProTaper in blue):
    Pleasanton, CA
    5,747
    Here's what I was able to measure. YMMV.
    A = 770
    B = 130
    C = 64
    D = 190
    E = 70
    F = 230
    Jan 2018
    313
    Oh wow, I guess my "jam something semi-straight in there and measure off that" method was a bit off. Thanks!
    If anyone would like some bars compared, I have pretty much all the ProTaper and Renthal stuff listed on Revzilla already done. Might turn this into a web-app if I find some free time.
    Jan 2018
    313
    Just a simple and crude bar simulator. Only the basic dimensions/positions are simulated (ie: no bend radius, etc..) but it should give a basic idea of how bars compare.
    ::: tw200.org - Handlebar Simulator :::
    Let me know if you'd like to see any other bars added. Future version will probably include fields to input your own values.
    Pleasanton, CA
    5,747
    Very cool!
    How about adding the 7/8" ProTaper ATV Hi which is a commonly used replacement bar for additional height?
    Thanks,
    Brian
    Jan 2018
    313
    Added the ProTaper SE ATV Low/Mid/High and the ProTaper SE Raptor bars.
    Pleasanton, CA
    5,747
    Quote Originally Posted by nihil View Post
    Thanks!
    Oct 2018
    Rural, South Carolina
    670
    This post needs it’s own thread and stickied by a mod in the Tech Section. Amazing work @nihil. You could even add various riser heights. This is very cool. Thanks for sharing.
    Darth and nihil like this.
    Offroad:
    TW200 - The Goat
    KTM 300 - Orange Dragon
    ATVs
    Onroad:
    Triumphs
    Way too many past bikes and builds to list. I won't bore you. Questions? Just ask.
    Jan 2018
    313
    Quote Originally Posted by Sthrnromr View Post
    Thanks! I figure I can't be the only one who has had trouble deciding what bars to go with. There are now 84 different bars modeled for the sim if you count the stock TW bars. Those models include the Renthal Fatbar CR High bend that I just got done putting on. I used the Rox offset adapters/riders to go from 7/8" to 1-1/8", they fit great and have a nice feel to them. I still need to get the mirrors sorted out, the GPS/phone mount mounted, and I'm waiting on a bar clamp kit for the Barkbusters (the 7/8" straight clamps don't fit, need the BTC-06 for tapered 1-1/8" bars).
    Also in the recently delivered pile to go on for this season:
    - Kickstarter
    - Shinko SR244 4.6 front tire (I know you guys like the 241, but sadly I spent more time on pavement than I'd like)
    - TW34 rear tire
    - New tubes front and rear with Ride-On
    - Front and rear brake pads/shoes
    Pleasanton, CA
    5,747
    Those bars look great! Not having a crossbar really cleans things up. I like your blue shorty levers too.
    (You're going to have to change your signature line now )
  1. Auto CAD Mechanical 2017
    By Skin Walker in forum Performance and Customization
    Last Post: 11-21-2016, 08:38 PM
  2. Pro Taper Handlebar interference Acerbis Handlebar guards?
    By GreyZuk in forum Performance and Customization
    Last Post: 06-30-2016, 06:59 PM
  3. Stock rear swing arm dimensions
    By c0rn_d0g in forum Technical Help
    Last Post: 11-18-2014, 06:23 PM
  4. Carb. Dimensions
    By 88trx in forum Technical Help
    Last Post: 11-03-2012, 12:55 PM
  5. Front Fender Dimensions?
    By drs6222 in forum Performance and Customization
    Last Post: 06-16-2012, 06:07 PM
