Is the high compression 74mm piston still available?
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By elime
Thread: Is the high compression 74mm piston still available?
    Junior Member Derrick Adams's Avatar
    Jan 2019
    4
    I am going to sleeve one of my cylinders to go up to 74mm and would like to buy a high compression piston for it. I am currently running a 71mm with 10.25:1. I don't expect much of a power gain going to the 74mm if I have to go down to 9.5:1 ratio.
    I found that someone named Frank offered a custom 11.5:1 piston with the 16mm pin. Does anyone know who that is, or if they are still available?
    Member TurtleWagon's Avatar
    Jan 2019
    62
    I am sending my head to la sleeve ,i believe they have a 10.75 piston mafe by CPM , weisco also has a couple different pistons for this ,check out LA Sleeves website
    6,984
    Try Venolia Piston Job # 137941 This is for a 70mm piston. Tell them you want this piston 74mm and they will make it for you. I am 98% sure you will have to modify the dome to get the compression down to where you want it so be prepared to do some cc'ing -- can be very tedious. Also, tain't cheap. The piston will cost more than a set of cast pistons for a small block Chevy.
    CC'ing (using anti freeze) to calculate the dome volume on a Wiesco piston:
    Miaugi likes this.
    Jan 2019
    62
    I might have to have them make me one looking for an aftermarket 2008 to 2012 xt250 piston with a 74mm bore and 16mm wristpin hole has not yeilded much, what about just a different connecting rod? Or boring out the wristpin hole to 17mm? I saw on another thread where a member suggested making 1mm bushings for the wristpin as well
    Jan 2019
    4
    I can get 74mm pistons with the correct 16mm pin diameter. Just trying to decide on compression ratio. I think I have what I need and may end up with a couple extra pistons to sell. The minimum purchase quantity is 4.
  1. Bushings for piston pin holes to have more piston choices.
    By Rpmfly1 in forum Performance and Customization
    Last Post: 02-25-2018, 10:51 AM
  2. High compression 74mm piston to suit TW/XT conrod?
    By mr200sx in forum Performance and Customization
    Last Post: 04-21-2017, 02:35 AM
  3. Replies: 3
    Last Post: 06-15-2015, 11:07 PM
  4. 2005 tw for sale Still available 12/12/12
    By robertstw200 in forum TW200 Classifieds
    Last Post: 11-25-2012, 05:50 PM
  5. Replies: 6
    Last Post: 06-07-2011, 05:56 PM
