15/50 sprockets
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 15/50 sprockets
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    I'd like some input from people who run a 15 tooth front and 50 tooth rear sprocket set up. I rarely ride off road, I'm a dirt road explorer that has to use two lane blacktop on occasion. How much lower end grunt is lost by going to a 15 tooth front? will it do 55mph comfortably? I'm not looking for a big change, just a little on the pavement. I live in the Arkansas hills, some of them are pretty steep.
    Senior Member mrbracket's Avatar
    Jul 2012
    Springtucky, Orygun
    631
    I run the 15/50 combo. I like it much more on the road. I haven't had a chance to get into woods yet, but I did play in the snow and it seemed fine, I spend most of my time in 2nd gear anyways when putting around.
    You've got a friend in the Bracket Business! Hidden Content
    Get your TW200 Parts at ProCycle! Hidden Content
    Member Matty Moo's Avatar
    Dec 2012
    Tecumseh, Mi
    30
    I just put a 15/50 on mine. Cruises comfortably at 55 and you really dont lose any significant amount of low end grunt. 1st gear is still pretty low.
    03 TW200 Moose handguards, F+R custom racks, Clarke TW tank, 15/50, RK o-ring and a bag for trips to the party store.
    Volvo ABS module repair and exchange at Hidden Content
    Sep 2011
    2,431
    Thanks for the reply's, I've had a 15 tooth sprocket on my shelf for two years, still trying to decide if I want to put it on. I appreciate the help.
    Apr 2011
    Martinsville Indiana
    2,089
    Do it you will like it especially if your not doing serious hill climbing. I run a 15/50 and like it. I ran a 15/47 on my last trip which was all pavement and a little bit of dirt roading and it was fine even at 5,000-6,000'. I could tell a difference off road with that gearing but i still got around just fine. To me a 15/50 at 55mph feels like the stock gearing around 50mph. Im guessing 4-5mph difference at the same rpm. Im sure there is a chart somewhere were you can figure all that out.
    Sep 2011
    2,431
    Thank you. I have looked at the chart, but it much better to hear from someone who has done it. So far I have three positive answers, any one else running 15/50?
    Senior Member atleastbehandy's Avatar
    Apr 2011
    Toronto, Canada
    250
    I am currently running 15/47. This is great for city streets as second gear is all I really need. But there is not enough top speed power for my occasional highway trips.
    So I have a 49 tooth rear waiting to install when the snow melts. I think (*desperately hope) 15/49 will be perfect.
    2005 TW200, 2" PowerMadd bar riser, Tusk D-Flex Hand Guards, PowerMadd Hand Muffs, Kick-Start, Valco Cup Holder, Givi E45N Top Case, Inline fuel filter, Storage Tube with MSR bottle, 45 Tooth sprocket, Stebel Low Tone horn, #130 Main Jet / no needle shims / 1.5 turns out on idle, Jimbo Shield, DID O-Ring chain, Clarke XT250 4.1 Gal tank, Custom Cycleracks
    Senior Member Dark Sol's Avatar
    424
    I ran 14/44, 14/45 and 14/47 on my TW. 14/45 and 14/44 were OK until you try to use 5th gear.....there's NO power and I think such tall gearing is actually doing more harm than good to the engine since it just doesn't have the power to pull.
    14/47 was much better. 5th gear actually has some power to tackle moderate hills, wheras with 14/44 even the slightest incline will have you downshifting, especially at 45 or below.
    15/50 or 14/47 is definitely the way to go. If you're just exploring dirt roads and not really tight trails 15/50 would be perfect for you - the biggest advantage being a more comfortable cruise on the highway.
    2008 CRF230L
    2006 CBR1000RR
    2007 CB919 - 70k Miles and still runs like new!
    * 2001 TW200 (Sold after 15k miles of fun)
    Sep 2011
    2,431
    Thanks guys, After a a day of playing with the sprocket-RPM calculator, and a hard objective look at where and how I ride. I've decided the factory got it right and the stock gearing is perfect for me.
    Senior Member Mhurchu's Avatar
    Sep 2010
    Dublin, Ireland
    112
    I use the 15-50 as it sounds better around town. You don't gain anything in 5th and you don't lose anything in 1st, it just sounds quieter with less revs thru the gears. The top speed test is questionable / hills & wind, and if your stuck in some mud are a couple of t going to save you ? People find combo's they like. Try a few. reds
  1. sprockets
    By Logan in forum General Discussion
    Last Post: 01-21-2011, 08:48 PM
  2. Chains/sprockets
    By Penerka in forum Technical Help
    Last Post: 01-07-2011, 03:25 PM
  3. sprockets
    By WINGNUT200 in forum General Discussion
    Last Post: 10-10-2010, 09:51 AM
  4. Speaking of sprockets
    Last Post: 10-04-2010, 09:04 PM
  5. Where to buy sprockets?
    By NinjaTech in forum Technical Help
    Last Post: 09-28-2010, 03:35 PM
15-20 sprocket on tw200
is 15 tooth sprocket too much for tw200
tw200 15 tooth sprocket
tw200 15-50 sprockets
tw200 sprocket set 15 50
