shinko 244 back tires
Results 1 to 9 of 9
Like Tree5Likes
  • 1 Post By Sthrnromr
  • 2 Post By Leisure Time Larry
  • 1 Post By RaZed1
  • 1 Post By nobade
Thread: shinko 244 back tires
    Junior Member jmks76's Avatar
    Apr 2017
    alberta
    1
    I was wondering if I can get the proper size for the shinko 244 back tires.
    I believe the front is 4.10-18 compared to 130/80-18. Can anyone tell me the back numbers to 180/80-14. if it is possible.
    Or any tire recommendation for the back tire.
    thank you jmks
    Oct 2018
    Rural, South Carolina
    670
    Short answer in my experience is no. If you want to stay with the same stock size tire and make no modifications, you’re pretty much stuck with the stock trailwing rear.
    Gulfrider likes this.
    Offroad:
    TW200 - The Goat
    KTM 300 - Orange Dragon
    ATVs
    Onroad:
    Triumphs
    Way too many past bikes and builds to list. I won't bore you. Questions? Just ask.
    Jul 2012
    Wet-ern Washington
    1,410
    Yeah, the Tdub 18" front is the size many bikes use as their rear. Very limited choices for tdub rear. Stock is actually a great tire for true dual sporting. There are a couple less aggressive tires available in our size. For more aggressive, the option is to try an atv's front tire as found all over this forum.
    Miaugi and Gulfrider like this.
    - Leisure Time Larry -
    Senior Member RaZed1's Avatar
    Oct 2015
    294
    There's only 3 actual tires for the TW's rear size. The stock trailwing, Bridgestone also makes a "70/30" street focused, mild dual sport tire, and the Suzuki VanVan's rear tire is also the same size. I'd also rate it as a 60/40 or 70/30, definitely more street oriented than off road.
    For anything more aggressive as said, you're looking to ATV tires. But the stock trailwing rear actually works pretty well, especially if you air it down to 3-4psi or so. Unless you're trying to drive up the side of a craggly mountain or sink it to the seat in mud, the stock rear will probably cover your needs pretty well.
    Willys714 likes this.
    Member nobade's Avatar
    Aug 2011
    Albuquerque
    34
    Don't forget the Shinko street tires. I have a set and they're great for most uses, even off-road if it's not muddy.
    Purple likes this.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Who's tried the street oriented Shinko tires ?.......how do they compare to the same tread pattern Bridgestone . TIA
    Mar 2015
    Ynys Môn
    4,593
    No personal experience - but - they are comparable to the 203/204 from what I've read. Bit softer, same grip ....
    - Hidden Content
    Jun 2011
    SW, Ohio
    2,518
    Thanks purple. Just trying to find out from users if Shinko's version wears , performs / lasts as long as Bridgestone 203 / 204......similar tread pattern. TIA
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,932
    I am trying the street Shinkos now. I haven't been able to tell a difference between the Bridgestone street tires. They work great on the street. I haven't tried off road yet.
  1. Shinko 244 Front Tire
    By Phantom99 in forum Performance and Customization
    Last Post: 07-31-2017, 12:30 PM
  2. Shinko 244 vs Kenda k270 vs IRC GP1 whos the winner?
    By weeman in forum Performance and Customization
    Last Post: 05-17-2015, 01:49 PM
  3. Phantom Bike Update/ Shinko 244 Report
    By Phantom99 in forum General Discussion
    Last Post: 11-01-2012, 02:03 PM
  4. FS: Shinko 244 "Golden Boy" front tire (NY)
    By 98940 in forum TW200 Classifieds
    Last Post: 05-18-2012, 03:34 PM
  5. Kenda K270 / Shinko 244 Rear Tire - Requests
    By praeses in forum Performance and Customization
    Last Post: 11-19-2011, 08:50 PM
